Go to Post Hey, I know that kid.... wait he is my son! - Mike Martus [more]
Unread 18-02-2004, 19:07
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: pic: 1067 electronics
Originally Posted by Matt Leese
While I can't get the wiring diagram to load to verify my statement, you are only allowed to wire the robot as shown in the wiring diagram. Given that the ground stud is in the wiring diagram, you do have to use the one that is provided. I doubt that your custom ground stud would pass inspection. While it may be a pain to change it, you probably need to be safe.
Matt
Yeah, you definatly can't use just angle bracket for your ground stud.
Besides, aluminum isn't a great conductor, you are introducing extra resistance into your system that *could* cause problems.
I was under the impression that you weren't allowed to do that much tampering (let alone substitution) in your control setup.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
pic: our super nicely organized electronics.. CD47-Bot Robot Showcase 4 18-02-2004 16:13
Question about buying electronics _GP_ General Forum 5 01-02-2004 12:43
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
