Go to Post Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs. - sanddrag [more]
Unread 19-02-2004, 23:29
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
Re: pic: 40-Amp Fuse Block
Last year, we had four 12" neon tubes mounted on our robot - two red and two blue. We swapped the connectors between matches so only the neon tubes that matched the rotating light would be on during the match. It was actually quite cool-looking.
Unread 20-02-2004, 00:23
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
we plan on putting neon tubes connected to a beat box so our robot glowes everytime it hits something.
"No drugs, not even alcohol cause the fundementa ills of society. If we're looking for the sources of your troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, freed and love of power" - PJ O'Rourke
Do we need to use the gnd stud and MAXI fuse block Noah Melamed Electrical 14 03-03-2004 20:38
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Reliable Connections to the fuse blocks. Al Skierkiewicz Electrical 0 09-02-2004 12:01
What else do we want? archiver 2000 63 23-06-2002 23:19
Blowing 60 Amp fuse archiver 1999 4 23-06-2002 22:07
