Go to Post I'm a bit wary about playing on the new fields, however, because of the Carson/Carver/Hopper/Tesla Curse. I hear no alliance from those divisions has ever won championships. - [more]
Unread 19-02-2004, 01:43
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: pic: Team 188 Closer Look
Congratulations to Woburn for once again creating a fabulous gearbox. For those who aren't familiar with team 188, this will be their third consecutive year using a six motor drive system. The addition of the shifter makes them even more dangerous.
How has it been performing during the testing? Has the new chain held up well?
I look forward to facing you guys in Pittsburgh and Toronto. Wow, it sure will be weird being on the other side.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 19-02-2004, 07:01
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
We also do not believe that there will be tons of pushing. Speed and precision are what will be important. Shifting gears will allow both. If and when power is needed ...... If you think that pushing will not be important, what would you be doing if someone where trying to uncap your goal or cap theirs for the win?
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 19-02-2004, 08:04
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
You and Ian can always do something about that you know . your swerve/strafe drive is pretty freaking impressive too.
Thanks everyone for the commentary. Let me just address a few things. First, you are all welcome to take a look at the regionals, I'd be happy to explain it, and get into an argument as to why it'll work . From experience, we have found that blowing breakers is very rare, and in fact we never did last year, despite having a non-shifting three-motor box. While there are hungrier F-Ps this year, we believe the ability to shift in conjunction with the backup battery keeping our controller on, will allow us to not overtax ourselves in matches. max is absolutely correct in saying that the three motors should not peak, because their current draw at that level is far higher than the motors will ever take. The gears are optomized and mated in such a way that something near the peak efficiency of each motor is used. The current is equally distributed. As a result, we will be able to get slightly more pushing power at the same amount of draw, divided over three motors; it won't be a full 'motor's worth' more, but it'll be enough to seriously mess with teams that thought they were powerful. According to the current curves, after about 10-15 seconds at stall in high gear, our robot will probably nuke itself, but we do not expect this to happen in normal match activities. It was also mentioned that versus a two-motor gearbox, we are not overtaxing our breakers, but the other robot will be. We will prevail. Bottom line, six-motor drive is a tried and true method for Woburn (although I have seen two other teams do it). Ask anyone at West Michigan or Toronto and they'll agree. Just try pushing us.
As it happens, we don't believe a huge amount of pushing will occur this year. That doesn't mean in our minds that we shouldn't be able to do it. Maybe more on the gearbox later from the source, but we'd like to keep a little mystery .
Unread 19-02-2004, 09:12
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I concur. In addition to all your comments I will add that it is almost impossible to trip the main breaker with the battery we have -- really.
As to whether 3 motors per side with a shifting transmission is needed, that is a topic for another discussion. Awesome job of engineering regardless of whether or not you acually need all that power.
Joe J.
Unread 19-02-2004, 21:33
Andrew Rosselet Andrew Rosselet is offline
None #0188 (The force from the north)
Andrew Rosselet is on a distinguished road
Send a message via MSN to Andrew Rosselet
So it has finally been noticed- our capability to shift.
Let's all point and stare, and then pat Tristan on the back for an amazing job
Unread 19-02-2004, 23:39
Hinkel Y.'s Avatar
Hinkel Y. Hinkel Y. is offline
FRC #0188 (Woburn Robotics)
Hinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura about
Send a message via MSN to Hinkel Y.
... As a result, we will be able to get slightly more pushing power at the same amount of draw, divided over three motors; it won't be a full 'motor's worth' more, but it'll be enough to seriously mess with teams that thought they were powerful. According to the current curves, after about 10-15 seconds at stall in high gear, our robot will probably nuke itself, but we do not expect this to happen in normal match activities. It was also mentioned that versus a two-motor gearbox, we are not overtaxing our breakers, but the other robot will be. We will prevail. Bottom line, six-motor drive is a tried and true method for Woburn (although I have seen two other teams do it). Ask anyone at West Michigan or Toronto and they'll agree. Just try pushing us.
I don't think the chain might break, but there's always a small possibility in low gear... Like last year for example, our three motor gearbox with our 25 chain was really weak... If you've seen us last year, every few matches, there was at least one chain broken and 3 at one point I think.
Good luck to everyone with their bot with only 6 days left...
Unread 19-02-2004, 23:43
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Team 639 will bring extra chains
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 19-02-2004, 23:48
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
25 mm chain saves a lot of weight, though i hope it doesnt break. We will have our pockets full with chains
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
