Go to Post Robots that don't obey the laws of physics will be checked for alien technology and magic. - Greg McKaskle [more]
Unread 21-02-2004, 00:19
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: pic: Lexan + Heatgun =
We used a 1300w heatgun. The board got a little tweaked from some areas getting hotter than others, but you cant tell it with out feeling the board. As for discoloring and bubbling, nah. The Lexan was 1/8" thick .. and took about 10 min to heat up the 34" strip of it. We had it clamped to the table with a 1x1 aluminum tube and some clamps on each side, and then one kid had a large 2x4 to bend the lexan.
Keep in mind, that lexan is flammable after 800 degrees (at least thats what the warning said on the plastic cover) So dont get it too hot .. and practice a few times on a spare piece, because it is a little tricky, and if you've never done it, you might wreck the expensive lexan.
Good luck.
(Edit)
Heres a picture of the setup we used to bend it ..
http://www.eaglerobotics.com/images/...an_bending.JPG
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
