Go to Post At IRI you have 72 of the best teams in the country. It could literally be held in a cornfield in the middle of Indiana and nobody would care, because the competition is simply that good. - Cory [more]
Unread 25-02-2004, 22:19
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: Mini-Arm - Controller
uvabrad825's Avatar
uvabrad825 uvabrad825 is offline
#0825 ('swi-va-gus 'mak-sa-mus)
uvabrad825 has a little shameless behaviour in the past
Re: pic: Mini-Arm - Controller
so is that used to control your arm during the match? or simply as a mini mock up of your arm?
Unread 25-02-2004, 22:23
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
that is how we control the arm that way it makes it easier for the driver. Trying to drive this arm with a joystick would be toooooooooo much.
Unread 25-02-2004, 22:26
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
so you actually control the real arm by moving the model arm? Do you use encoders or what to measure its placement?
Team 1257
Unread 25-02-2004, 22:31
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
Pots are most likely used. We did the same thing last year and it works sooo nice, as long as you have the time to tune the code to react correctly to the movement in the model. I am curious. How did you guys do it? Is it as simple as finding the difference between the actual and the requested pot values, dividing by a constant and adding the signed int to 127? I'm still working on code for a model, right now we are using joysticks and probably will for competition but its a project of mine.... How do you do it?
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
nuggetsyl's Avatar
FRC #0025
we use pots to mesure where the robots are is
shaun
Unread 25-02-2004, 22:33
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
that is one of the coolest things I have ever seen. Great job 25!
Ryan
FRC/FLL volunteer since 2005
Unread 25-02-2004, 22:34
nuggetsyl's Avatar
FRC #0025
well i am sorry i can not answer that not because i do not want to but because that would have to come for one of the kids programing it rob or bharat. Programing the robot is something i can not do but i am sure once one of the guys see this the will tell all,
Unread 25-02-2004, 22:44
uvabrad825's Avatar
that is truly awesome...
Unread 25-02-2004, 22:47
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I must say, that is a genuine idea. I thought about making a potentiometer to create a control for our elevator and/or arm elbow, but it was not nearly as engenious as this. Reminds me a lot of a boat throttle now that I look at it
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 25-02-2004, 22:48
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Team Role: Electrical
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
i saw one of those last year...i thought it was like the coolest thing...great job! (i want one)
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 25-02-2004, 22:55
nuggetsyl's Avatar
FRC #0025
wow which team had one
Unread 25-02-2004, 23:03
Nick Fury Nick Fury is offline
Nick Fury has a spectacular aura aboutNick Fury has a spectacular aura about
I would like to see a wiring diagram of your controller if you happen to have one.....perdy please?????
Unread 25-02-2004, 23:18
nuggetsyl's Avatar
FRC #0025
crap on me right now i do not have one but i can get you one for the nj reagional
Unread 25-02-2004, 23:25
REVving up for a new season
FRC #2848 (All-sparks)
we have a control for our arm also that uses pots to control height.....ours is a little simpler as in we are using 1 knob but we have stops at the common heights ie. top of the goal, hanging height....so it takes the guess work away from the drivers
pic: 461 Arm CD47-Bot Robot Showcase 1 18-02-2004 12:01
pic: The long arm of the law. CD47-Bot Robot Showcase 12 16-02-2004 22:43
Anyone have a pic of my HUGE bottle of Mt. Dew from Bash @ The Beach 2003 mini comp? Elgin Clock Off-Season Events 1 09-01-2004 01:03
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
Robot Controller arm David Kelly Technical Discussion 0 28-06-2001 16:37
