Go to Post I bet a lot of us (mentors and students) got into this line of work first because we wondered how things work, and stayed in it because we thought "I can make that work better". Thus starts a life-long battle between perfection and time. So far, time is ahead. - petek [more]
Unread 26-02-2004, 13:52
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
Re: pic: Mini-Arm - Controller
Originally Posted by nuggetsyl
that is how we control the arm that way it makes it easier for the driver. Trying to drive this arm with a joystick would be toooooooooo much.
Just this Control component has a lot of award potential!
Good luck!
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 26-02-2004, 17:11
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Originally Posted by mightywombat
Pots are most likely used. We did the same thing last year and it works sooo nice, as long as you have the time to tune the code to react correctly to the movement in the model. I am curious. How did you guys do it? Is it as simple as finding the difference between the actual and the requested pot values, dividing by a constant and adding the signed int to 127? I'm still working on code for a model, right now we are using joysticks and probably will for competition but its a project of mine.... How do you do it?
We used a Axis control code. It wasnt too easy to program this thing. Basically we used the difference between the pots and set the speed accordingly. Also this thing has been programmed with a lot of safety measures. It also has a timer set, so incase we get stopped by anything, it multiplies the speed forcing movement. Ask if anything else
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 26-02-2004, 21:44
Adams High Man Adams High Man is offline
#0245 (Adam Bots)
Adams High Man is an unknown quantity at this point
Send a message via AIM to Adams High Man
Yea, i was origionally going to make a mini-arm to control ours, but then i decided to write inverse kinematics code! Unfortionatly, we ran out of time to actually TEST our robot, but it looks very hopeful. This way, we can control our 3 joint arm using 1 joystick. We can tell it to go anywhere in x-y space.
It was interesting to write, because i had to make my own integer trig library.
Unread 27-02-2004, 16:23
Alaina's Avatar
Alaina Alaina is offline
J = Pf - Po
FRC #0814 (Megaforce Squadron)
Alaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to behold
Send a message via AIM to Alaina
814 did the same thing last year with their stacking arm.
We won leadership in controls at Sacramento for it.
"It's cool to be a geek!" -- Dave Lavery
"It's all about the math." -- Mark Leon
Unread 27-02-2004, 16:56
so whos car is now missing its headlight switch and knob? it looks like its off a VW.
Unread 27-02-2004, 18:09
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Shhhhhh. Big Mike hasn't noticed yet...
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 28-02-2004, 01:15
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
We control a single rotating arm with a similar setup. The drive
to the motor is derived from the difference of the values returned
by the pots. This produces a torque on the motor that is proportional
to the error. The result, if you increase the gain to get good precision,
is a harmonic oscillator. If you run in to that, you add a damping force
derived from speed of the arm, calculated by reading its position on two
(or more) successive radio packet cycles between the OI and the RC.
The arm then behaves as a damped harmonic oscillator. With well
chosen damping it won't oscillate at all. Use quality pots that do a good
job of maintaining continuity as they are turned.
Unread 28-02-2004, 01:51
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
oh i have noticed, its just that my car is so pathetic that needing a pair of pliers to turn my headlights on doesnt change much (good thing this is a joke or else i would be pretty mad my cars headlight knob was gone)
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 28-02-2004, 08:36
Aignam's Avatar
This Space For Sale
AKA: Anthony Mangia
Team Role: Scout
Funny story about this. The team was at the Bristol-Myers Squibb shop, and I kept hearing the programmers on our team and the BMS tradesmen talking about "pots", and I couldn't count the times I heard them make references to the "pots", since we were programming the arm. It took me most of the day to figure out that "pots" were potentiometers. Then everything started making sense. Alas, clarity.
Unread 28-02-2004, 10:34
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
You wouldn't believe how many pot jokes were flying around while we were making our arm controllers...
Unread 28-02-2004, 10:36
Sometimes, we even forgot which pot was hooked up to which part, and we used to upload the code and wonder what went wrong. Thank God for the "Kill Switch"
-= Bharat Nain =-
Unread 28-02-2004, 10:44
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Oh we'd believe it - I'm sure that it does on almost every team that uses pots. It gets much worse when you break one of them and someone accuses you of "smoking the pot"
Don't feel bad - my blinker stopped working the other day. It still lights, but it doesn't "blink." It's quite interesting having to changing lanes or attempting to complete a Michigan Left turn while actuating a turnsignal by hand!!!
Note: Yes, I do even make the "blink" sound myself too.
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 28-02-2004, 10:47
Yeah, we actually did smoke one of them. I accidentally hooked the wires up backwards, so that ground and power were next to each other (that's what I get for not having the right colors of the thin wire I was using!)
When I turned it all the way to one side, it started to glow red and smoke came pouring out. We quickly pulled the power
Amazingly, it still worked for a while, then it crapped out.
Unread 28-02-2004, 11:09
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I think team 308 was the first to do an arm about this, all the way back in 2000. Here is a thread about it: http://www.chiefdelphi.com/forums/sh...ad.php?t=10706 Unfortunately, I can't seem to be able to dig up any pictures of it.
Unread 28-02-2004, 19:16
AKA: Dr. Brooks
no team (WRRF)
A potentiometer has been called a pot since the early days of radio.
I have been asked for the "thingamajig" for the arm measurement,
to which I replied the proper way to ask for the part is: "Dr. Brooks,
I would like you to give me the pot." The teenagers in the shop thought
it was very funny. The nine dollar Bournes pots from digikey, very
good for continuity as you turn them, are, of course, smooth pots. In
our shop everyone was careful wiring them, so no one smoked the pot.
pic: 461 Arm CD47-Bot Robot Showcase 1 18-02-2004 12:01
pic: The long arm of the law. CD47-Bot Robot Showcase 12 16-02-2004 22:43
Anyone have a pic of my HUGE bottle of Mt. Dew from Bash @ The Beach 2003 mini comp? Elgin Clock Off-Season Events 1 09-01-2004 01:03
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
Robot Controller arm David Kelly Technical Discussion 0 28-06-2001 16:37
