Go to Post If my shop was snowed in and my unfinished robot was sitting in there, I'd dig it out with a plastic spoon or melt it out with a Bic lighter if I had to. Every hour counts. If there's a will, there's a way to make it happen. - sanddrag [more]
Unread 28-02-2004, 13:12
RogerR's Avatar
RogerR RogerR is offline
AKA: Roger Riquelme
FRC #3844 (Wildbots)
Re: pic: 571's new gearz loose weight
Originally Posted by Jones571
y do your trani'z run the length of your bot?
we're using direct-drive (spur gears) instead of chain or pulleys to transfer power from the motors to the wheels of our bot
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 28-02-2004, 13:16
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
y do that the weight must be a killer. It really eats up your weight limit quickly? im not seeing the benefit of that.
Unread 28-02-2004, 13:28
RogerR's Avatar
AKA: Roger Riquelme
actually, in the begining, we weighed about 78 lbs, but after some lightening holes in the gears, turning down the hubs, and replacting many steel parts with aluminum, we dropped almost 15 pounds. we didn't want to deal with the loss of effciency and other problems that chain drives can have if they aren't designed properly. we actually modeled our drivetrain after team 25, so we aren't the only ones to do this.
Unread 28-02-2004, 13:30
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
yea i can understand that 25 had an sweet drive train last year i cant watie to see what they did this year.
pic: last minute weight loss CD47-Bot Robot Showcase 11 26-02-2004 19:41
pic: last minute weight loss CD47-Bot Robot Showcase 6 26-02-2004 01:17
pic: Team 1156 - Weight Measure CD47-Bot Robot Showcase 5 25-02-2004 23:50
pic: 571 2004 new gearz.. CD47-Bot Robot Showcase 7 22-02-2004 20:10
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
