Go to Post Soon, some of those teams will learn to rise about current and former powerhouses. - Akash Rastogi [more]
Unread 28-02-2004, 14:22
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Re: pic: The LocTite Monster
The same thing I believe happened to us when we used lexan and loctite. The stuff just cracked at the holes.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 28-02-2004, 15:15
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
If you find you need to LocTite screws or bolts into plastics or there's a chance the LocTite can come into contact with plastics (remember it doesn't take much to react with certain plastics) it's best to wrap teflon tape on the threads. You don't need a lot either, one wrap will do. This will prevent the fastners from vibrating loose and still allow them to be removed if neccesary. If you have access to the back side of the screw or bolt you could use a nut with a nylon insert.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 28-02-2004, 15:30
personally I would not use locktite on any electronics - there is too great a chance that you will have to replace them between matches - they are all susceptable to failure from a number of causes - and when you need to swap them out, you need to be able to do it quickly.
if anything, put double nuts on and torque them into each other. You really cant tighten down the screws on the electronics or the plastic cases will crush.
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
