Go to Post Coming from one of the biggest mecanum fanboys in FIRST- have fun, drive fast, and forget the haters. - Brandon Zalinsky [more]
Unread 28-02-2004, 15:30
Re: pic: The LocTite Monster
personally I would not use locktite on any electronics - there is too great a chance that you will have to replace them between matches - they are all susceptable to failure from a number of causes - and when you need to swap them out, you need to be able to do it quickly.
if anything, put double nuts on and torque them into each other. You really cant tighten down the screws on the electronics or the plastic cases will crush.
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
