Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Unread 02-29-2004, 05:40 PM
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Re: pic: Team 57 Revealed
That arm looks quite familiar.. Looks like you're using the Fisher Price to move the arm up, are you using all of the gears that came in the gearbox? Also, how are you winching and pulling the robot up?
Looks very sleek, I like the black theme
Unread 02-29-2004, 08:33 PM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
There's a winch directly beneath the base of the arm, with a spectra cable running up and through the inside of the arm. The winch is actually a small lightweight boat winch, currently driven by the WINDOW motor. We might be swapping in a drill mtor in low gear and engaging the racheting mechanism on the winch, since the WINDOW motor is a little slow at the moment. Luckily it's mostly a drop in change since the input on the winch is now a 5/8" keyed shaft.
Last edited by Kevin Sevcik : 03-01-2004 at 01:17 AM. Reason: Can't remember a seat motor isn't a window motor
Am I the only person with this job? A. Leese General Forum 55 06-22-2006 08:10 PM
Real names, please Andy Baker General Forum 131 07-21-2004 10:07 PM
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 03-31-2003 07:34 PM
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 02-25-2003 09:07 PM
