Go to Post I'm gonna go back to my corner and write some more code... - Kevin Watson [more]
Unread 01-03-2004, 13:03
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: SPARK 562's Robot
Unread 01-03-2004, 13:04
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
Re: pic: SPARK 562's Robot
Any questions?
SPARK 562: Students Pursuing Applied Robotics Knowledge
2006 BAE Granite State Regional: Finalists with 319 and 176
2006 BAE Granite State Regional: Winners of Motorola Quality Award
2004 BAE Granite State Regional: 7th Seed
2004 Mayhem on the Merrimack Champions! Thanks, 61 and 1289!
Unread 01-03-2004, 14:02
Crop-Circles's Avatar
Crop-Circles Crop-Circles is offline
The Fifth
AKA: Mike Boehl
#0066 (Flyers)
Crop-Circles has a spectacular aura aboutCrop-Circles has a spectacular aura about
Send a message via AIM to Crop-Circles
Ball control at it's greatest!
I am a little curious what you're using to drive...
Hope to see you in finals!
Rule #1: Fix any and all problems with duct tape and/or zip-ties.
Rule #2: Always respect the authority of the conch.
Rule #3: Goto 20
Rule #4: Don't touch the hair.
Rule #5: (see rule #4)
Rule #6: Never call us the robotics club. We are a team, NOT a club.
Rule #7: The power of the fuzzy compels you.
Rule #8: Show EARL and CHARLIE the respect they deserve.
Rule #9: If it starts glowing, don't touch it.
Rule #10: Gracious Professionalism is a balance. Never leave home without it.
Break any of the above rules and you will be FIRED!
Unread 01-03-2004, 14:47
Engineer
#0562 (SPARK 562)
We're using the drill motors in 1st gear to drive with the provided 4.5:1 reduction system. They do the job, and it let us spend time designing and building other stuff. We used the Chiaphuas the last couple years because we felt the game required a lot of pushing power, but this year we didn't see it as much of an issue.
The arm uses the van door and globe motors, and the hopper is driven by a window motor.
Unread 01-03-2004, 16:33
teno121 teno121 is offline
#0121 (RhodeWarriors)
Team Role: Student
teno121 will become famous soon enough
Send a message via AIM to teno121
does your arm roll the ball in or open & close?
Unread 01-03-2004, 16:40
Engineer
#0562 (SPARK 562)
The big arm opens and closes. There is plenty of force holding the ball in place. We can pick a big 2x ball up off the floor or the small goal, and place it on the small goal or the tall goal (without climbing the steps). We can also knock the 2x ball off a goal by swinging up under it.
The small balls are picked up by rolling them into the frame, and to dump them we just reverse the direction. There are two drums that spin in opposite directions to do that. The opening for small balls is probably about 24" so it's pretty easy to get them.
By the way, 121, I'm really looking forward to seeing how your 2x ball grabbers work! You have a pretty unique design (as usual).
Unread 01-03-2004, 21:15
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: pic: SPARK 562's Robot
This is a beautiful machine! Great dual function in using the cage as the ground link on the arm. Well done!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 01-03-2004, 21:17
What is that blue stuff on the tires?
Unread 01-03-2004, 21:25
trev2023's Avatar
trev2023 trev2023 is offline
None #1236 (Phoenix Rising)
trev2023 will become famous soon enough
Send a message via ICQ to trev2023 Send a message via AIM to trev2023 Send a message via MSN to trev2023 Send a message via Yahoo to trev2023
It looks like an omni-wheel so that they can turn easier.
Unread 01-03-2004, 21:54
Engineer
#0562 (SPARK 562)
Close.. it's big blue zip ties. They're attached like snow-chains, with rings on the sides, then looped over the wheel. Without them, we had the infamous bounce while turning.
Matt, thanks for the compliments! It's pretty simple and functional. This is easily the most flexible robot our team has designed.
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
pic: Our new robot CD47-Bot Robot Showcase 3 20-01-2004 00:01
pic: TEAM # 123 - 2003 Robot for "King of the hill" CD47-Bot Robot Showcase 3 03-03-2003 08:56
XCats - robot pic on our website archiver 2001 0 24-06-2002 01:06
