Go to Post In my book the team building experience of the kids training the engineers in the operations on the field would be invaluable. It might not get a trophy but you win far more in the long run. - Wayne C. [more]
  #31   Spotlight this post!
Unread 23-02-2004, 22:47
ThetaDot's Avatar
ThetaDot ThetaDot is offline
here come the warm jets
#1481
Team Role: Animator
ThetaDot can only hope to improve
Re: pic: T3 Controlls (team 68 truck town thunder)
do you want a cookie or something?
  #32   Spotlight this post!
Unread 24-02-2004, 07:50
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
What?
As for the other, more straigntforward commets/questions, it is an automotive neon light, bought for a cheap 15 bucks at a local walmart.
Let me clarify the drill housing. We broke a drill, or took one apart at the very least. So, we were left with the plastic case that everything goes into. We trimmed it to fit, and wired connectors to the teminals. so all it really is, is a housing that a battery slides into.
We also wired a switch on the dongle/battery which allows us to switch between AC and DC power. Long story short, we can use the battery to power our operator interface. This should make tethering a lot more "wireless".
Thanks again for all the comments
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
  #33   Spotlight this post!
Unread 24-02-2004, 08:25
Austin's Avatar
Austin Austin is offline
Go TechnoKats!
FRC #0045 (TechnoKats Robotics Team)
Austin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to all
Send a message via AIM to Austin
What do you use the ignition switch for? To turn on/off the power to the LEDs, Neon lights, OI?
Austin Butler| Mac Addict | Purdue AAE | President, Sigma Gamma Tau | ENS USN/Student Naval Aviator
2002-2005 driver | 2004 Lead Mechanical | 2004-2005 Co-Student Leader | TechnoKats Robotics Team 45
Need a gearbox? Omniwheels? Check out AndyMark.biz
  #34   Spotlight this post!
Unread 24-02-2004, 08:33
Hoonigan
no team (no team)
The Ignition is a disabler for the built-in dongle. When the key is not inserted, or turned to the right, it acts as "diabled", otherwise, it enables it.
Next to it is a safety switch for autonomous testing, which is more or less a joke on our programmers.
Here's the story...
We were showing some of the high-up engineers who wanted to see what we had done so far the robot. And, this happened to be the first night that it could move. SO, we had it on the field, and we had it wired correctlly (this time) and everythign was great. Well, Aucther, one of our programmers, told me to flip a dial on the joystick (filter), all the way down, as i would get ore acceleration. Whups. As i tapped the sticks to see which way the bot was facing, it flew towards our team leader and the group of engineers. another tap in the oppisite direction sent it into the wall. I pulled the key, and almost strangled mike. Your a good guy thou, aucther!
Anyways, the switch is "on" when we are testing our very dangerous robot, and it moves on its own, so we have to take extra caution!
-Alexander S. McGee
  #35   Spotlight this post!
Unread 01-03-2004, 00:51
ThetaDot's Avatar
#1481
Team Role: Animator
OH NO I'M EATING YOUR COOKIE!!!! : [[[[[[[[[[[[
  #36   Spotlight this post!
Unread 01-03-2004, 09:34
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The tether cable powers the OI. If you're tethered to a live robot, you're powered.
  #37   Spotlight this post!
Unread 01-03-2004, 20:57
Hoonigan
no team (no team)
Yes, however, for robot demonstrations, you require an ac adaptor to run the robot without a thether. We no longer need to have the controlls plugged in while doing demos. This means that we can drive the bot at parades much easier.
-Alexander S. McGee
  #38   Spotlight this post!
Unread 02-03-2004, 00:24
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Very, very SHINY!!
/me stares into reflection
Are you trim adjustments exposed? If not, you may want to make the joystick openings a little bigger.
And does that think have a handle? I feeel very sorry for the driver that has to carry it all the time. Way to much responsibility trying not to damage it.
I felt bad handling the painted board ours were on.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Competition at UTC New England Rick Gibbs Regional Competitions 6 02-04-2002 09:25
Novi Kickoff Seminar List (Tentative) Joe Johnson General Forum 1 05-12-2001 13:47
