Originally Posted by Tyler Olds
Did you fix your problem where your balls were bridging and getting stuck?
From what I can remember, we haven't experienced stuck balls to be a problem. If it becomes one, we can simply reverse our other roller, and the zip ties will slap the balls on that side to move the stuck balls out of the bridged position.
Also what are you using for "wheels" in the front of your bot where the funnel is?
We have an additional crab module in the middle of the front of the robot, right past where the picture cuts off, identical to the two in the rear.
