Go to Post How about "The 2007 FIRST Robotics Competition International World Championship Event Of Atlanta Consisting Of Competition, Gracious Professionalism, Robots, And Geeky Fun"? Somehow I doubt it will catch on... - raymaniac [more]
Unread 04-03-2004, 00:20
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: Team 710 Drive module
Originally Posted by Stud Man Dan
The loss of structural integrity compared to the weight gained is not worth it.. WE milled out 1 sprocket.. ( more like speed wholes.. but they were big ones :-\ ) and we lost less than .1 lbs
I don't disagree we could use some weight. But when it comes down to it.. its not really a ton
It was barely noticeable
You could remove a considerable amount of mass from each of those plates while doing relatively little to change the structural integrity of the design.
Think about bridges, for example. Trusses support immense load, yet they're largely open space. Cutting a similar pattern of triangles into plates such as yours is often an effective way of reducing weight while maintaining strength.
--Madison--
...down at the Ozdust!
Unread 04-03-2004, 00:32
REVving up for a new season
FRC #2848 (All-sparks)
it's amazing how simalar those are to ours.....
Unread 04-03-2004, 00:33
linky no worky
EDIT: Picture link above fixed now.
Unread 04-03-2004, 00:34
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
From what i have seen you guys 73, us 710, and 258 have a similar design with the "gurney" style drive.
Penn Class 08
Unread 04-03-2004, 00:35
fixed
Unread 04-03-2004, 00:44
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Well except for the fact that have a considerable amount of spacers running through the centers where these designs would be cut out. And we did run into problem withs spherical our cuts weakening the system. Infact the forks we milled where the only ones we had problems with
I was not saying that it couldn't be done.
I was saying that the difference in the weight made is basically nothing. its 3/16th alluminum and we could cut out a max of about 1x2 inches. Weighing only a few grams. ( to be exact its about 0.0360 lbs per piece )
If it had been better designed in the beggining when those parts were designed it could have been designed with the cut outs inplace. But with our current system it can not be done with enough effectiveness to cause reason to do it. But again, the extra work done on it, and the weight gained we felt were too minute to deal with under our certain time restraints.
THanks for the advice tho keep it coming
Dan
ps. see our bot in action ( sorry for bad editing job, I'll be re-editing this weekend hopefully ) View Us
Our forks in action
Us hanging because of our lifting system
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 04-03-2004, 00:54
abeD's Avatar
Heres a lower resolution vid (5MB as compared to 25MB)
Low Res 710 Video
ps .avi's soon to come if this one doesn't work (people have told me that it won't work on their computer.)
Penn Class 08
Unread 04-03-2004, 01:03
that is very cool....we only use ours on the back of our robot and have an omni wheel bar that comes down and suppports the front...i really like the automation of the system...what are you using for the feedback... limit switches?
i like it and look forward to seeing this bot inaction
Unread 04-03-2004, 01:09
abeD's Avatar
Thanks!
We use banner sensors, one in front of each wheel. The way it is set up is that when one of the sensors gets over teh step it pulls either the front or the back up. The driver controls if the banner sensors are activated or not with the trigger button on the joystick. I think you can see the banners in one of our posted pics. One thing we have to do at comp is reset the banners to the hdpe on the step. Works well for the most part and takes one thing out of the driver's hands (not that me and dan couldnt do it )
Penn Class 08
Unread 04-03-2004, 01:10
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Greg, as abeD said earlier, we're doing the same type of drivetrain. We are going to be using limit switches for feedback. We considered using other kinds of proximity sensors, but due to time and money constraints, we chose to go with the limit switches we had lying around the lab.
How about you guys?
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 04-03-2004, 01:14
abeD's Avatar
look here you can see the banner in front of the back wheel.
Penn Class 08
Unread 04-03-2004, 01:21
we have a banner sensor on each weel that counts wheel speed.....as for climbing we either have nothing or we are using limit switches...i belive when the robot was shipped we had no automated way of getting up the stairs but i was promised it was being worked on, and since i have been on spring break i have no idea what progress has been made. i know that we are using a banner to determine height of our arms and with a linear pot controling the height of the arms....the nice thing about this is that we have clicks (for lack of a better word) at specific heights (stationary goal, mobile goal, hanging) so that the driver doesn;t have to guess and can just snap to the height.....i do think that automating the climbing with this type of drive is essential and we will have it by cleveland....anyway i am going to bed cause i am driving to trenton tomorrow morning for the NJ regional.....good job guys and good night
pic: Team 60 Drive Train Parts CD47-Bot Robot Showcase 17 07-02-2004 01:58
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
