Go to Post Seeing a bunch of teams from Indiana and probably Michagin competing at the same time.... If I wanted to see that, I'd just go to the Championship in Atlanta. :yikes: - Barry Bonzack [more]
Unread 03-07-2004, 07:14 PM
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Re: pic: #171 is back for more!
Very nice Jeff!!!!!!!!
I see you brought back your snow blower tires, mega traction there!
Couple of questions:
From what height on the field can you hang (floor, 6", 12")?
Can you trigger the bonus ball?
What are the pneumatic cylinders standing vertical on the front for???
Great job guys, looks like another BSH workhorse from Platteville.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 03-07-2004, 07:21 PM
Beast314's Avatar
Beast314 Beast314 is offline
Team #171 President
AKA: Jeff Mathes
#0171 (Hardcore Engineers)
Beast314 is on a distinguished road
Send a message via AIM to Beast314 Send a message via Yahoo to Beast314
1)From what height on the field can you hang (floor, 6", 12")?
2)Can you trigger the bonus ball?
3)What are the pneumatic cylinders standing vertical on the front for???
Good questions and thanks for the complements.
1) We must be on the top platform to hang, but we shouldn't have too much trouble with that.
2) Yes
3) we use those to kick from a 4 wheel drive to a 2 wheel drive, more mobility. They can also be used for extra height when hanging.
Jeff Mathes
Team #171 President
Alumni of Team #93
Unread 03-07-2004, 09:37 PM
What takes the hook up? Winch? Rack and pinion?
Unread 03-07-2004, 10:11 PM
Beast314's Avatar
Team #171 President
AKA: Jeff Mathes
It's telescoping. There is a 1/4" pitch chain in the inner portion of the boom. The chain is held in at both ends. That's run up then by the Van Door motor with a sprocket on it.
Jeff Mathes
Team #171 President
Alumni of Team #93
Unread 03-07-2004, 10:51 PM
Is the chain just runing a tanget to the sprocket or is it somehow wrapped around somewhat. Could you post a picture, it sounds very interesting.
Unread 03-08-2004, 02:29 AM
Beast314's Avatar
Team #171 President
AKA: Jeff Mathes
I don't have a good pic for you right now. The chain runs tangent to the sprocket. If you've used Bosh, 80/20, or anything like it you'll find it has channels in it on each side. The chain we use fits in that channel such that it runs in tangent to the sprocket. With the motor fixed and the chain fixed on both ends to the inner tubing it will run up or down. Hope this helps to clarify things, I'll try to get a pic for you though.
Jeff Mathes
Team #171 President
Alumni of Team #93
What if FIRST changed back to 2 coaches? D.J. Fluck General Forum 45 01-08-2007 06:25 PM
pic: Team PIC of 354 Westinghouse HS CD47-Bot Robot Showcase 4 02-29-2004 12:15 PM
pic: Team 61 Giving Buzz a Piggy Back ride CD47-Bot Extra Discussion 2 05-15-2003 11:21 PM
Image Discuss: Team 171 back for the 9th year. CD47-Bot Robot Showcase 1 02-21-2003 02:11 AM
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 03-17-2002 10:09 PM
