Go to Post 10:50PM, 1/14/16: I predict that hot dog wheels will grace Einstein before Mecanum wheels will. You heard it here first. - CalTran [more]
Unread 03-07-2004, 10:11 PM
Beast314's Avatar
Beast314 Beast314 is offline
Team #171 President
AKA: Jeff Mathes
#0171 (Hardcore Engineers)
Beast314 is on a distinguished road
Send a message via AIM to Beast314 Send a message via Yahoo to Beast314
Re: pic: #171 is back for more!
Originally Posted by sanddrag
What takes the hook up? Winch? Rack and pinion?
It's telescoping. There is a 1/4" pitch chain in the inner portion of the boom. The chain is held in at both ends. That's run up then by the Van Door motor with a sprocket on it.
Jeff Mathes
Team #171 President
Alumni of Team #93
Unread 03-07-2004, 10:51 PM
Is the chain just runing a tanget to the sprocket or is it somehow wrapped around somewhat. Could you post a picture, it sounds very interesting.
Unread 03-08-2004, 02:29 AM
Beast314's Avatar
Team #171 President
AKA: Jeff Mathes
I don't have a good pic for you right now. The chain runs tangent to the sprocket. If you've used Bosh, 80/20, or anything like it you'll find it has channels in it on each side. The chain we use fits in that channel such that it runs in tangent to the sprocket. With the motor fixed and the chain fixed on both ends to the inner tubing it will run up or down. Hope this helps to clarify things, I'll try to get a pic for you though.
Jeff Mathes
Team #171 President
Alumni of Team #93
What if FIRST changed back to 2 coaches? D.J. Fluck General Forum 45 01-08-2007 06:25 PM
pic: Team PIC of 354 Westinghouse HS CD47-Bot Robot Showcase 4 02-29-2004 12:15 PM
pic: Team 61 Giving Buzz a Piggy Back ride CD47-Bot Extra Discussion 2 05-15-2003 11:21 PM
Image Discuss: Team 171 back for the 9th year. CD47-Bot Robot Showcase 1 02-21-2003 02:11 AM
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 03-17-2002 10:09 PM
