Go to Post Wait, crap... totally forgot that I needed to build an intake. :eek: - Andrew Schreiber [more]
Unread 27-02-2004, 20:16
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: Team 33: BUZZ 9
Unread 27-02-2004, 20:18
itskeLz's Avatar
itskeLz itskeLz is offline
itskeLz*
AKA: kelly huang
#1463 (DA TRANS-FOH-MUHHZ)
itskeLz is an unknown quantity at this point
Send a message via AIM to itskeLz
Re: pic: Team 33: BUZZ 9
sorry, but i can't tell from the picture just how tall it is. also, because of its quite rectangular shape, do you think it'll tip easily? or do you think that maybe bouncing balls (ie: when the balls are dropped after knocking off the 10pt ball) may knock it over? cool design you guys! best of luck!
..spittin it through the wire..
itskeLz*
team 1463 represent!
FIRST mentor
team 1137
the noblemen
Unread 27-02-2004, 20:32
Cool! after the championship you can use for a birdcage :c)
Unread 27-02-2004, 23:39
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
It's all five feet tall. The balls will not knock it over, the top frame is all thinwall aluminum tube, light as air. The frame itself weighs at most 3 or 4 lbs. The front roller frame is another 5 or 6 lbs. All of the rest is in the bottom of the robot. What you can't tell from the picture is that the chassis is only about an inch from the ground, and the battery, big drive motors, transmissions, air tanks, and all of the other weight is within 3 inches of the ground. We know better than to make a robot that will tip when a ball hits it. All the other team would have to do would be to throw a ball at us.
Here's a better picture of the drive module....it's the best I have...
http://www.freewebs.com/madness256/Buzz%5F9%5F2.jpg
Unread 27-02-2004, 23:51
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
20 BALLS! ZOUNDS!
Twenty balls are about 15 more than we hold. It will be interesting to see what you can do at the Detroit Regional.
Perhaps we will compliment eachother well.
See you at Wayne State.
Joe J.
Unread 27-02-2004, 23:53
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
Sounds good to me, it's about time we team up with the chiefs again to finish what we started in OCCRA!
Last edited by Paul H : 27-02-2004 at 23:58. Reason: I don't believe it! I spelled Chiefs wrong!
Unread 09-03-2004, 16:46
Mike K Mike K is offline
Battery Boy
#0033 (Killer Bees)
Team Role: Student
Mike K is on a distinguished road
Send a message via AIM to Mike K
If Paul thinks it good i think it is good.
Detriot will be great.
See ya then!
Unread 10-03-2004, 14:56
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
looks great 33, congrats on your win in Virginia. Hope to see you down in nats. **Maybe we will team up with 469 again and have a repeat of occra ** jk lol good luck to you.
Unread 10-03-2004, 15:43
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
Haha...this one has a little more dependable drive than the OCCRA bot, and I'm going to say the same holds true for the chiefs!
We could have a reMATCH of OCCRA....Or we could just have a rePEAT of the sweet repeat! Either works for me!
-Paul
