Re: pic: 222 3 speed closeup/cutaway
As you can somewhat tell, the word, well, name "FRED" is on the inside of the tranny. I just noticed it myself but, I believe it is there because he is NOTORIOUS for greasing, greasing, and well, greasing. We should be ok and he should have some fun this year, but thanks for the heads up. |
This is certainly a nice, compact design. Reminds me of my dual range Suzuki I had in the late '70's. I have looked at how to easily do the machining and am very interested in seeing your white paper.
As for the lube. We are lucky that we run short matches and that the total life of our robots is measured in hours. Greasing on a regular basis allows us to run on the edge with our designs. I do agree with Kevin's professor provided this was on production equipment. The Suzuki I had (actually I still have the motor and gearbox) was steel on steel but ran in an oil bath. |
Speaking of Kevin....
I just had a test today in that class, and it reminded me that the issue is worst if the metals are of the same or similar composition, same hardness, and relatively low hardness. The threshold for same hardness is within 5 HRC of each other. Soooo.. if you have a hardened steel shaft there, and the inside of your gear isn't hardened you should be reasonably ok. Also, I'd still be concerned even though this isn't production equipment. Our prof showed us a few examples of some coupling threads that suffered from galling, and that's obviously not a high-cycle kind of thing. so mostly, I'd just keep it lubed and keep these things in mind in your white paper. |
Thanks for the heads up guys. We tried filling the bottom with oil but that got too messy.
We ran the trannies for hours and didnt have a problem. We give our robots the robust test every year... Our robot never missed a shift once and that is almost amazing considering we always had problems with shifting the drills in previous years. |
Preface...Control systems guy with fetish for understanding mechanicals.
How do the balls capture the gear? And how do you control which gear gets captured? |
In the picture, the balls in the shaft sit down in thier holes, not above the exterior surface of the shaft. We have a rod that moves in and out of the shaft which pushes the balls up locking them into the little notches in the gears. The rod is on springs so when it touches the 4 balls (on one gear) on the inside of the shaft the balls do not jump up into the gear by force they go when ready so not to grind. the balls fall back into place once the rod is removed. So by moving the rod to different places it locks in different sets of gears choosing our speed. I hope i didn't confuse anyone to badly. |
How do you prevent the balls from moving radially outward when the shaft is spinning? I would think that the centrifugal force on them from the spinning shaft would tend to push them out into the slots in the gears.
I (and from reading this thread, many others also) would be very interested in seeing a photo or drawing of how your sliding rod works to move the balls in and out. I would also be interested in knowing how you cut the slots in the gears. If you put a sensor on both shafts, I think you could make a really slick automatic transmission with this gearbox. When the software figures it's time to shift up to the next higher gear, indicated by high motor speed, the control computer would put the gearbox in neutral, then drop the motor speed down so that the input shaft speed, as measured by the period between sensor input triggers on the input shaft, matches the period measured on the output shaft, adjusted for the gear ratio of the next desired gear. At this motor speed the desired input/output gears are spinning at exactly the same speed. Then the contoller would shift to the desired gear, the balls pop into place on the output gear, and the controller applies power to the motor, accelerating away in the higher gear. A similar sequence can be used to down-shift, where the motor speed is increased while in neutral to match gear speeds. The system would work like a sensor-controlled synchromesh. (I would call is "automatic sensor synchromesh" if not for the unfortunate acronym . Maybe "sensor controlled synchro - SCS would be a better term.) In any case, this would be a neat project to work on. Any chance of getting some more details? |
The force your refering to is just inertia (a body in motion will remain in motion unless acted upon by an outside force). This is a comon mistake that people make mistaking intertia with centrifugal (which does not exist). The ball bearings remain in the shaft until the air inside shaft pushes the balls out and locks the gear.
Even if they did push out the balls would be forced back in by the rotation of the gears and shaft |
Thank you for the clarification.
From what you are saying, am I to imply that you use pneumatics to control the balls? (you wrote: The ball bearings remain in the shaft until the air inside shaft pushes the balls out and locks the gear.) Henry seemed to indicate that there was a central rod in the axle that slid back and forth, and somehow pushed the balls out. Did you use a water jet to cut the slots in the gears? |
#10
Sorry for the typo...
I ment to say that the rod is used to push the ball bearings inside the slots in the gears. The air cylinder moves the rod between high and low and a 2nd cylinder wedges it in 2nd gear. We made the slots in the gears using a manual mill. Most parts were made by hand and the side plates were done on a brand new CNC. |
#11
Very cool, I think I might even understand how it works. Thanks for the explanation.
#12
awesome awesome tranny...we saw u guyz and experienced you in action at chesapeake. good job. but we still pushed you....j/k j/k, but we did!! no hard feelings
#13
Not really. You guys were chasing us around in first gear.
I do recall from the video when both of our robots front wheels were off the ground to form an A. And our base operator knows that we do not get involved with pushing other bots. He knows how easy we tip. We will have to get in a real match at PARC I do like your drive train though. Its very sweet that you can change it out quickly if you have too. |
#14
Thanks for all the complements and questions. We are always around in the pits too for specific detail. Brad is geting good at explaining these. As for the pushing... I was instructed specificly not to push anyone, just to accomplish the task at hand. We do tip, but I have not tipped since practice rounds, note they are practice rounds. I was trying new stuff. I also only ran away in first gear, because well, I am stupid, no, um, i just didn't shift up Figured we were going to the step to climb. It didn't matter when I got there so why risk hitting the corner of the stairs? BUt I will break out second gear some more if anyone wishes to see it. We ran our auton in second and I occasionaly jumped up when making the drive for a distance. Plus, balls +any other gear than 1st = bad, most of the time. We don't run up on them a lot with our lexan teeth but they get bent. So I avaoid higher gears and balls. BAD!!. Anyway, don't worry out there in Philly 11, I will show some more of our machine's capabilities. Annapolis was just a warm up . As Cliff has said. We've got some stuff up our sleeves...Last edited by henryBsick : 03-24-2004 at 06:19 PM. |
#15
amazing design.
We are rookies trying to build stuff in the offseason (yeah for us the offseason has already started and that sucks). Anyway, is the only thing keeping the gears from lateral movement along the axle the pressure from the sides, or it there a locking mechanism? Wouldnt the friction of the gears touching reduce efficiency? Also, any generic advice on building trannys would be great. We have limited machining capabilities (no high tech stuff i.e. CNC etc.). |
| pic: 716 Dual Motor/Dual Speed | CD47-Bot | Robot Showcase | 18 | 04-23-2004 01:51 AM |
| pic: 222 3 speed on the robot | CD47-Bot | Robot Showcase | 6 | 03-11-2004 09:39 PM |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 10-07-2003 03:04 PM |
| pic: 716 single speed | CD47-Bot | Extra Discussion | 2 | 09-09-2003 03:51 PM |
