Go to Post Adversity should be seen as a challenge and not as an obstacle. :D - waialua359 [more]
Unread 12-03-2004, 21:46
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: pic: de_c4rt
I am a mechanic...and those black things between the "legs" and the cart bed are very recognizable. Those are the "airbags" that you hear about it you ever hear about airbag suspension on cars. That is an air tank in the middle of the under carriage. The leg is attached to the cart beyond the airbag at the point that is the origin of the angle between the cart and the leg. The airbag is between the cart bed and the leg and therefore within the angle. By adding air into the airbag and inflating it, it widens the angle and lifts the cart. Each airbag is operateed independently, so you can cause some crazy tilts as seen in the picture.
See you in DC!
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
