Go to Post "As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything." — Barack Obama - Ted Weisse [more]
Unread 03-15-2004, 09:57 AM
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: pic: 222 3 speed closeup/cutaway
The force your refering to is just inertia (a body in motion will remain in motion unless acted upon by an outside force). This is a comon mistake that people make mistaking intertia with centrifugal (which does not exist). The ball bearings remain in the shaft until the air inside shaft pushes the balls out and locks the gear. Even if they did push out the balls would be forced back in by the rotation of the gears and shaft
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 03-15-2004, 10:28 AM
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Thank you for the clarification.
From what you are saying, am I to imply that you use pneumatics to control the balls? (you wrote: The ball bearings remain in the shaft until the air inside shaft pushes the balls out and locks the gear.) Henry seemed to indicate that there was a central rod in the axle that slid back and forth, and somehow pushed the balls out.
Did you use a water jet to cut the slots in the gears?
Unread 03-15-2004, 11:50 AM
AKA: Bradley Rigdon
Sorry for the typo...
I ment to say that the rod is used to push the ball bearings inside the slots in the gears. The air cylinder moves the rod between high and low and a 2nd cylinder wedges it in 2nd gear.
We made the slots in the gears using a manual mill. Most parts were made by hand and the side plates were done on a brand new CNC.
Unread 03-15-2004, 01:11 PM
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Very cool, I think I might even understand how it works. Thanks for the explanation.
Unread 03-24-2004, 05:23 PM
Brandon Holley's Avatar
awesome awesome tranny...we saw u guyz and experienced you in action at chesapeake. good job. but we still pushed you....j/k j/k, but we did!! no hard feelings
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 03-24-2004, 05:52 PM
AKA: Bradley Rigdon
Not really. You guys were chasing us around in first gear. I do recall from the video when both of our robots front wheels were off the ground to form an A. And our base operator knows that we do not get involved with pushing other bots. He knows how easy we tip.
We will have to get in a real match at PARC
I do like your drive train though. Its very sweet that you can change it out quickly if you have too.
Unread 03-24-2004, 06:16 PM
henryBsick's Avatar
henryBsick henryBsick is online now
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Thanks for all the complements and questions. We are always around in the pits too for specific detail. Brad is geting good at explaining these.
As for the pushing...
I was instructed specificly not to push anyone, just to accomplish the task at hand. We do tip, but I have not tipped since practice rounds, note they are practice rounds. I was trying new stuff. I also only ran away in first gear, because well, I am stupid, no, um, i just didn't shift up Figured we were going to the step to climb. It didn't matter when I got there so why risk hitting the corner of the stairs? BUt I will break out second gear some more if anyone wishes to see it. We ran our auton in second and I occasionaly jumped up when making the drive for a distance. Plus, balls +any other gear than 1st = bad, most of the time. We don't run up on them a lot with our lexan teeth but they get bent. So I avaoid higher gears and balls. BAD!!. Anyway, don't worry out there in Philly 11, I will show some more of our machine's capabilities. Annapolis was just a warm up . As Cliff has said. We've got some stuff up our sleeves...
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 03-24-2004, 11:53 PM
indigofire79 indigofire79 is offline
#1257 (Parallel Universe)
indigofire79 is an unknown quantity at this point
amazing design.
We are rookies trying to build stuff in the offseason (yeah for us the offseason has already started and that sucks). Anyway, is the only thing keeping the gears from lateral movement along the axle the pressure from the sides, or it there a locking mechanism? Wouldnt the friction of the gears touching reduce efficiency?
Also, any generic advice on building trannys would be great. We have limited machining capabilities (no high tech stuff i.e. CNC etc.).
Unread 03-25-2004, 12:03 AM
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
There are a few white papers on trannys on this site. There are many good white papers. Our team has posted a white paper for our 2-motor, 2-speed gearbox, that only requires a manual mill and lathe to create.
Another good and simple gearbox is team 33's 4-speed automatic gearbox this year. I don't know that there is a white paper available for it, but you might be able to get a lot of information from them about it. It supposedly can be made with a lathe and a drill press with an X-Y table.
Just some suggestions. There are tons of designs out there, as you can see by the variety just this year. A lot of it sometimes depends on the game. Good luck with your offseason work!
See you in DC!
Unread 03-25-2004, 09:01 AM
None #0612
I am planning to build one of your transmissions in the off-season, and hopefully develop an automatic shift algorithm for it, which of course I will share on this discussion board. I have a few (actually, several) questions on your design:
  1. It looks like you have used a fairly thick walled 1" diameter tube as the main axle. Was this machined out of a 1" rod?
  2. What material did you use?
  3. What diameter is the inside hole?
  4. How far out to the 5/16" ball bearings protrude when they are pushed out by the inner ring?
  5. Do you need to have two sizes of holes on the axle to prevent the balls from going in too far? Could you not just have the balls drop down and touch the spring?
  6. Does the shifter rod rotate with the axle, and if so, how do you push or pull on it?
  7. It seems that the balls might have a tendency to push themselves out due to the rotation of the axle, or at least drop down into a lower notch in a gear when the axle is at rest due to gravity. Do you have any problem with the balls coming out prematurely into the wrong gear?
  8. How much force is needed to push the shifter ring against a set of balls to select the next gear?
Sorry to have so many questions, but I am quite interested in this design you have some up with, and want to experiment with it. I think it shows great promise for future development.
Unread 03-25-2004, 11:35 AM
jjdebner's Avatar
jjdebner jjdebner is offline
Jdizzle
AKA: Joshua Debner
None #0195 (Cyber Knights)
jjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud of
Send a message via AIM to jjdebner
Those are really ellegant tranny's I always thought of a three speed as hard and complicated. This just blows my mind that it can be achieved that simple. Good Job. Now we should work on simplifying OUR 2-speed hahaha
- 2004 Entrepreneurship Award, UTC Regional
- 2004 3rd Place, NJ Regional
- 2004 J&J Sportmanship Award, NJ Regional
- 2006 Championship Finalist
- 2006 Innovation in Control Award, UTC Regional
- 2006 Championship Inovation in Control Award
- 2007 Winner UTC Regional
- 2007 GM Industrial Design Award, UTC Regional
Unread 03-28-2004, 08:06 PM
AKA: Bradley Rigdon
TO answer some of your questions:
1. Yes I believed this was machined from 1" steel rod.
2. above
3. I am not sure what hole you mean?
4. Less than half of the bearing goes up inside the gear. This is to prevent the bearing from getting stuck inside the gear.
5. You might be able to get away with only 1 hole. However we used 2 different size holes.
6. Yes the shifing rod does rotate with the axle. We have a brass piece that is captured inside a thing that looks like a pulley.
7. No the balls do not push out inside the gears when the axle is rotating. This was talked about earlier in this thread.
8. You could do it with your pinky finger. If the holes are not aligned then you have to push on the springs. This takes more force.
I hope to get a white paper compiled soon. I have yet to wait till FIRST season is over probably. I am very busy. I also have a VICA competition coming up soon.
Any more questions?
Unread 03-29-2004, 11:41 AM
None #0612
Thanks for the reply Brad. Your comments have been very helpful.
The hole diameter I was asking about is the hole you drilled in the 1" steel rod, through which the spring and ball-bearing pusher slides. It looks to be about 5/8" from the photo.
Thanks
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 04-23-2004 01:51 AM
pic: 222 3 speed on the robot CD47-Bot Robot Showcase 6 03-11-2004 09:39 PM
pic: dual speed gearbox CD47-Bot Extra Discussion 9 10-07-2003 03:04 PM
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 03:51 PM
