Re: pic: 222 3 speed closeup/cutaway
Thank you for the clarification.
From what you are saying, am I to imply that you use pneumatics to control the balls? (you wrote: The ball bearings remain in the shaft until the air inside shaft pushes the balls out and locks the gear.) Henry seemed to indicate that there was a central rod in the axle that slid back and forth, and somehow pushed the balls out. Did you use a water jet to cut the slots in the gears? |
Sorry for the typo...
I ment to say that the rod is used to push the ball bearings inside the slots in the gears. The air cylinder moves the rod between high and low and a 2nd cylinder wedges it in 2nd gear. We made the slots in the gears using a manual mill. Most parts were made by hand and the side plates were done on a brand new CNC. |
Very cool, I think I might even understand how it works. Thanks for the explanation.
| pic: 716 Dual Motor/Dual Speed | CD47-Bot | Robot Showcase | 18 | 04-23-2004 01:51 AM |
| pic: 222 3 speed on the robot | CD47-Bot | Robot Showcase | 6 | 03-11-2004 09:39 PM |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 10-07-2003 03:04 PM |
| pic: 716 single speed | CD47-Bot | Extra Discussion | 2 | 09-09-2003 03:51 PM |
