#11
Re: pic: 710 Hanging
I must admit, you guys pulled off what I was skeptical about. I remember you telling me about that in week 1 or 2... and I kind've laughed, but I'm really glad you guys did it... Once you guys are connected to that bar... your the fastest one to pull up
Only recommendation I'd make is to make a hook-on system for your grabber... so like if you KNOW in a match you won't need the 2x ball, you can put it on... so that it takes less time to grab that bar cause that did hurt you one or two times when it slipped off. Maybe even a switch of some sort to indicate to you when the arm is high enough to close in case a scenario comes up again where the 2x ball on the mobile goal blocks your view... would make it simpler for Dan to work. Great job guys! |
| pic: A hanging mess! | CD47-Bot | Extra Discussion | 5 | 08-03-2004 15:35 |
| pic: Team 710 Drive module | CD47-Bot | Robot Showcase | 20 | 04-03-2004 01:21 |
| pic: Team 48 Robot Hanging | CD47-Bot | Robot Showcase | 1 | 01-03-2004 20:22 |
| pic: Team 340 Hanging and Uncapping | CD47-Bot | Robot Showcase | 1 | 23-02-2004 11:02 |
| pic: ROBBE Hanging | CD47-Bot | Robot Showcase | 6 | 16-02-2004 20:26 |
