Go to Post In engineering, it's important to use the appropriate tools and not more resources than are required. - AdamHeard [more]
Unread 15-03-2004, 22:19
dan 322's Avatar
dan 322 dan 322 is offline
The FIRE team
AKA: Dan Clemons
FRC #0322 (The Fire Team)
dan 322 will become famous soon enoughdan 322 will become famous soon enough
Re: pic: Fischer Price motor are very powerful
Originally Posted by Joe3
We've done even better with this. We have two f-p motors powering our arm, with a 16:1 reduction outside of the stock gearbox reduction, and during different points in testing we
1. buckled arm
2. tore gearbox mounting point out of chassis
3. snapped a solid 44 tooth (35 chain) sproket.
Beware of the power.
We also use two FP motors, but only a 10:1 Reduction. We also had a vandoor motor with them until weight became a problem.
2001 Kettering Kickoff Champs
2002 Western Michigan Finalist
2002 Kettering Kickoff Champs
2003 Pittsburg Regional Champs
2003 Great Lakes Regional Finalist
2004 Great Lakes Regional Champs
2004 Website Award Winners
2004 Newton Division Finalist
2005 Great Lakes Regional Finalist
2005 Motorola Quality Award
2006 Motorola Quality Award
2006 General Motors Industrial Award
Unread 17-03-2004, 12:15
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We use the FP's through the drill transmission and then reduce another 32.5 times for our use. It will viewable tommorrow at the UTC NE Regional.
Unread 17-03-2004, 14:21
Joe Johnson Joe Johnson is online now
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I agree with those who discussed being too aggressive in lightening efforts.
In my opinion, this is a better example of a not leaving enough meat on the bone than the power of the F-P motors.
Actually power had nothing to do with this failure, I suppose it was torque that killed it not torque X speed (i.e. power).
Joe J.
Unread 17-03-2004, 14:57
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
You mean it's not SUPPOSED to look like that??!?
Actually, the first time I looked at this image, I thought that Team 322 had manufactured an elliptical gear to tailor the delivered torque to certain angles of inclination of their arm (similar to high-end/competition bicycle cranks and chain wheels). I saw the kink in the lower portion of the ellipse and thought "wow - they bent their chain gear; too bad after all that work to cut the custom gear shape."
Then I realized that it really did start out as a round chain gear, and modified that reaction to "WOW!!!" Lessons learned: 1 - even more respect for the F-P motors. 2 - gotta go double-check strength calculations for lightening gears. 3 - elliptical gears could be very useful; something to remember for next year.
-dave
Unread 17-03-2004, 20:12
dan 322's Avatar
The FIRE team
AKA: Dan Clemons
Joe J.
Yep, the sprocket was supposed to see only torque from the Window motors (very weak), but because we were still learning with the arm we hung incorrectly. This put the torque of 2 FP's reduced 10:1 on the sprocket. Unfortunately when you try to do a lot of tasks (big ball, hang, climb, push) with your robot, weight becomes a big issue REAL FAST. This requires the team to lose a little bit of robustness. This is what it's all about though, making the simple parts to replace the weak link. We replaced the sprocket within 5 minutes and had time to eat before our next match. We have learned a lot over the last 5 years. We also ripped off an robot finger trying hang incorrectly and blew out our trick wheels when the bot fell. It was awesome, our arm was still on the bar. I think we should have gotten 50 pts. for it.
Unread 17-03-2004, 20:22
BoyWithCape195 BoyWithCape195 is offline
AKA: Ben Gagne
FRC #0195
BoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant future
Send a message via AIM to BoyWithCape195
Exclamation Re: pic: Fischer Price motor are very powerful
Oh course Fisher price motors are powerful *opens gear box and gazes at big gears!* They also are made to move up to arund 150 pounds, so if its moving your arm...that alot of power for not so much weight.
Module 7 gear -- fischer price motor archiver 2001 6 23-06-2002 22:55
Fischer Price Motor help needed archiver 2000 10 23-06-2002 22:07
Fischer Price Part Number? bmusser Technical Discussion 0 02-02-2002 12:26
fischer price motors Paul Marshall Motors 4 12-10-2001 09:44
