Re: pic: 222 3 speed closeup/cutaway
With our pneumatics, we can only go all the way out all the way in or no air presssure and ram the wedge at a 90 degree angle to push the the cylinder into 2nd. It only gives us three postitions, therefore eleminating the possibility of a neutral. If we used other methods like a lead screw or what you atre describing, yes, we could have neutral position. Our original plan was for a leadscrew and a pto actuall, we scrapped it to geta faster lighter shifter. Brad will post an inventor soon I think. Thanks for the comments, questions, and suggestions. We are always eager to answer more. Last edited by henryBsick : 03-16-2004 at 11:14 AM. |
I will try my best without the inventor pic. Our pneumatic cylinder pushes a rod that ataches to two shifting forks. They thn move the "plunger" to push out the balls. The rod that the cylinder pushes has aplate on it. On this plate are two roll pins positioned verticly. When the air is dumped from the primary cylinder and put into the cylinder with the wedge, the wedge pushes between the two roll pins moving the primary cylinder a little bnit left or right depending on which gear we were coming from to go to second. [edit/]Here is a pic. of it on the bot [/edit] |
I have done a sketch of a possible shifting mechanism for this type of transmission, and inserted it below. I have spaced the 1/2" gears 1/8" apart and designed the 'bump' on the shifting rod so that there is a neutral in between each gear. This would allow the robot controller to match shaft speeds before shifting into the next higher or lower gear. I'm not sure whether this is really necessary, as I don't know how rough the shifting is with team 222's existing design. (Any comments here from 222?)
The next item needed is some means of moving the shaft 3/16" per slot to engage each gear - 1,N,2,N,3. This needs to have some "springyness" (technical term here) to ensure that it doesn't jam the balls into the gear before they are ready to go. I don't yet understand how 222's transmission does this. ![]() |
| pic: 716 Dual Motor/Dual Speed | CD47-Bot | Robot Showcase | 18 | 04-23-2004 01:51 AM |
| pic: 222 3 speed on the robot | CD47-Bot | Robot Showcase | 6 | 03-11-2004 09:39 PM |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 10-07-2003 03:04 PM |
| pic: 716 single speed | CD47-Bot | Extra Discussion | 2 | 09-09-2003 03:51 PM |
