Go to Post This is a benefit of the district model. It brings the events back into the schools. - ezygmont708 [more]
Unread 16-03-2004, 18:23
/Pyro's Avatar
/Pyro /Pyro is offline
FRC #0292 (PantherTech)
/Pyro is an unknown quantity at this point
Re: pic: Fischer Price motor are very powerful
I am confused about this picture. It looks as if the gear was designed that way. It appears to be bolted twice to an aluminum block that appears to be attatched to an arm. Some clarification would be nice.
Nic Fouts, 2013 Team 1306
Unread 16-03-2004, 19:25
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
I'm sure the two tabs used to be collinear. The tremendous moments about each of the bolts caused them to slip from their fastening and swing around bringing the rather thin rim with them. It is an easy fix. Just extend each tab so that it goes all the way across. That way, there is one member that can take some shearing and tension forces instead of all off the torque being transferred right to the two bolts in the form of a giant force couple.
Make no mistake: The Fisher-Price motor is an absolute beast. So be careful when pocketing sprockets! Leave some steel to help you out.
-Carl
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 16-03-2004, 23:05
Will Hanashiro Will Hanashiro is offline
GM/Kettering Mentor
FRC #0322 (F.I.R.E)
Will Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really nice
Send a message via AIM to Will Hanashiro
this is what happened to our arm (322) durring one of our earlier attempts to hang. this particular sprocket wasnt directly connected to the fishers, but to two window motors that control our wrist. we tried to hang with our wrist slightly bent, and because window motors lock in place, the sprocket gave into the weight of a 130 lbs bot trying to hang. gravity tried to straighten the wrist, and the motors tried to hold the wrist in place, and crunch... there goes our sproket. ...but yea, it was the fishers that lifted the robot up to begin with...
yep that pretty much what happened.
West Michigan Regional #1 Seed
2006 GLR Motorola Quality Award
2006 WMR GM Industrial Design Award
Kettering University ME Class of 2009
Unread 17-03-2004, 09:27
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
We have similar drive sprockets from last year, only it bent into a triangle because it had three mounting points. We learned Our lesson though, leave a ring around the center when you lighten sprokets.
Unread 17-03-2004, 12:04
Code\\Pilot Code\\Pilot is offline
< Only smart people see my avatar
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Code\\Pilot is an unknown quantity at this point
Send a message via AIM to Code\\Pilot Send a message via MSN to Code\\Pilot
one of our f-p motors got burned in the quarter finals, so we were not able to hang, they were powerful, but get too much heat in direct pulling.
So we lost 50 points and the chance to go to the semi finals.
Join the Red revolution, give me some RED rep!!!!
if it doesn't work, don't force it. Go get a bigger hammer.
int run = 0;
int robot_chasing_you = 1;
if (robot_chasing_you)
run = 254;
I got 48 Gmail invites left, pm me with your e-mail so i can send you one.
Module 7 gear -- fischer price motor archiver 2001 6 23-06-2002 22:55
Fischer Price Motor help needed archiver 2000 10 23-06-2002 22:07
Fischer Price Part Number? bmusser Technical Discussion 0 02-02-2002 12:26
fischer price motors Paul Marshall Motors 4 12-10-2001 09:44
