Re: pic: 222 3 speed closeup/cutaway
Thanks for the update. It clarifies things quite a lot. What size hole did you use for for the 5/16" ball-bearing, and what thickness or axle did you use? From the drawing, it looks quite thick.
Not a problem. I love to answer questions. Brad has all the dimensions written down somewhere for the inventor so he can post it. 3 2/3 hrs till i leave for annapolis!!!!!!!!!!!!!!!!!! [edit/] I just found out about the PM sorry for the wasted post.[/edit] Last edited by henryBsick : 03-17-2004 at 10:19 PM. |
Congratulations on your stellar performance in Annapolis! Sorry I missed it. I see that you won every match, and seldom got less than 100 points. Very good numbers. You also got some awards - excellent work. Was one of these for your transmission?
Regarding your transmission, I want to clarify the size of the ball bearing that you use - is it 5/16"? Also, you mention that there are 2 different size holes - I guess these are the holes through which the balls protrude. Can you describe what you mean by 2 different sizes - are the holes stepped - that is the entrance hole is bigger than the exit - so the ball doesn't come out to far? |
As far as I know we recieved both design awards for our tranny at Annapoilis, I was not there, but I did get word of our acheivements. All of this was because of our Mechinist Bob. Unfortunatly, due to weight issues, we only had 2 gears ( I am unsure of this, please correct me if I'm wrong) to run with, but still the tranny proved it's value. THANKS BOB ![]() |
On the awards...Friday's Delphi Driving Tomorrow's Technology award was primarily for the tranny and the way the students were able to describe it to the judges. Saturday's Motorola Quality Award was the combination of the tranny, the robustness of the machine and the applicability of the overall design to the game. |
I am glad to see Frank has rose up from the dead. He hasnt posted in years.
Yes their are 2 different size holes. The bearing 5/16 and they are steel. The first hole is the size of the bearing and is drilled partway down into the hollow shaft. The 2nd hole is all the way thru so that the bearing doesnt fall down thru. This hole also allows the bearing to protrude thru the hole so we can push it up thru. I do not know the depth of the first hole or the diameter of the second hole. sorry |
This is the shifting fork. You can see the brass piece attached to the shifting fork.
More pics of the transmission can be seen at: http://www.tahsroboticsteam.org/pictures.htm Last edited by team222badbrad : 03-29-2004 at 05:17 PM. |
That's absolutely beautiful. What power source are you using to shift?
We use a pair of 3/4 inch air cylinders. With a throw of about an inch.
They can be seen in this picture: http://www.chiefdelphi.com/forums/pi...&quiet=Verbose One air cylinder shifts between high and low and the other shifts the transmissions in 2nd! |
#10
You mentioned that the force required to shift the transmission is quite light. Would it be possible to use the torque produced by a servo motor to shift?
I have drawn a sketch below of the concept. Basically, the inner shaft shifter rod is pushed and pulled back and forth by a pushrod attached to a wheel that is rotated by a servo, in the same way that you would push up/down an aileron on a model plane. The servo can be directly controlled by any PWM output on the robot controller. The servo wheel can be set to any desired rotational angle by varying the PWM output duty cycle. Certain angles would correspond to 1st, 2nd 3rd gear, as well as the neutrals in between each gear. Do you think a servo would have sufficient power? It would certainly be a smaller, lighter-weight solution compared to using pneumatics, and could probably provide control of 3-4 gears. Because the electric motor in a servo is not particulalry strong, it may be possible to eliminate the springs in the original design. If the transmission is not aligned properly for the shift to occur, the servo motor just stalls, and waits the fraction of a second required for the next gear to line up. It would then rotate just the right amount to engage the ball bearings on the next sequential gear. ![]() Last edited by jskene : 04-04-2004 at 05:28 PM. |
#11
Alternative to servos?
On another note, how does the CIM work? We built a transmission over the summer, where the CIM was drawing huge amounts of power, and ended up for this year with something similar to the two motor design in the white papers. Does a single CIM work? And if so, doesn't manual shifting get confusing during a fast paced match? Back to the earlier SCS thing. It might be possible to design a "steptronic" type control that normally shifts automatically, but could be overidden for climbing, &c. Last edited by CJO : 04-05-2004 at 04:18 PM. Reason: show signature, it wasn't there |
#12
Re: Alternative to servos?
Have to check on the rotary pneum.'s thanks for the idea. Yes, it probably is possible to shift with a servo but we wanted to get away from them. We had troubles on the drill transmisions with the number being in the right spot to tell the servos where to stop. They worked every match but they occasionaly caused us grief. We checked the power curve for the CIM's to figure in on a good ratio. I drive it and it isn't bad. I shoot over some where quickly and then just get into a lower gear to push, pull, climb. It really isn't bad. I was talking to our programmer about adding a new switch and a current sensor to make it auto. We might we might not. It isn't really neccesary for this game to much.(for us anyway). But back ont to topic, no it isn't hard on the driver (me). I am lost with the whole SCS thing since I saw the first post about it. -Henry Last edited by henryBsick : 04-04-2004 at 08:07 PM. |
#13
Re: SCS
Re: SCS
| pic: 716 Dual Motor/Dual Speed | CD47-Bot | Robot Showcase | 18 | 04-23-2004 01:51 AM |
| pic: 222 3 speed on the robot | CD47-Bot | Robot Showcase | 6 | 03-11-2004 09:39 PM |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 10-07-2003 03:04 PM |
| pic: 716 single speed | CD47-Bot | Extra Discussion | 2 | 09-09-2003 03:51 PM |
