Go to Post The bottom line is, what works best for YOUR team is what the best solution is. - EricH [more]
Unread 19-03-2004, 16:32
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: US!!!
Unread 19-03-2004, 16:33
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Re: pic: US!!!
Does that T-Slot system allow you to grab the bar, or get the 2x ball? It's hard to tell... and how does it work I'm curious, is it a scissor extender?
Chopsaw? Chopsaw.
Unread 19-03-2004, 19:57
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: pic: US!!!
It is a telescoping arm that can be used to uncap and to hang. It is extended and retracted via a cable-pully-winch system. However that alone cannot lift the robot so we have a large pneumatic piston to help it up. The whole arm rotates up to vertical.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 19-03-2004, 20:00
Robot Lifeguard
Re: pic: US!!!
I like the system, it is kind've how we originally planned... I hope it works out for you guys. Good luck!
Chopsaw? Chopsaw.
Unread 19-03-2004, 20:41
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Re: pic: US!!!
It's the only thing that has been working so far. We lost a motor, two climbing pistons, and a PWM so we haven't been able to make it to the bar. But when we did, the arm was perfect.
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
