Go to Post When we stop asking ourselves the hard questions, whether as team leaders or in life, then we are failing. - Al Skierkiewicz [more]
Unread 21-03-2004, 18:55
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: pic: Lexan: Bulletproof, but not robotproof
Nice robot, but where's the broken lexan?
Unread 21-03-2004, 19:17
Cate Dumez's Avatar
Cate Dumez Cate Dumez is offline
#0173 (RAGE)
Cate Dumez is an unknown quantity at this point
Send a message via AIM to Cate Dumez
yeah, where is the broken lexan?
anyways, it looks like a practice round by the lack of alot of people in the backround. the 10 point ball might have just been put back in the field after being knocked out. i saw that happen alot on thursday.
at utc, a 10 point ball was only knocked into the field once during qualifying and elimination rounds and we happened to be playing in it. our partner got it to our human player but it didnt get into the goal. it was cool to see one on the field though.
has anyone else seen a 10 point ball in an actual round?
cate d
Unread 21-03-2004, 19:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I believe the lexan being referred to is the top section of the ball grabber, which is sticking at an angle upwards.
There was one match at Sacramento in which there was one ten point ball in each goal.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 21-03-2004, 22:15
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Yea .. it was the upper piece of the claw. If you look closely at the picture, you can see the piece of Lexan bent WAY up.
What happened, was when we drilled the holes for the spacers, the lexan cracked a little (little being less than 1cm long). It worked flawlessly for over a month, then it decided to kick the bucket at the competition. Lovely. Thanks again to Team 599, who provided us with a piece of lexan large enough to make another claw piece.
Heres a better picture of the damage:
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
pic: Team PIC of 354 Westinghouse HS CD47-Bot Robot Showcase 4 29-02-2004 12:15
pic: Lexan + Heatgun = CD47-Bot Robot Showcase 4 21-02-2004 00:19
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
