Go to Post Incidentally, the best Delphi is ChiefDelphi! :) - Max Lobovsky [more]
Unread 21-03-2004, 19:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Lexan: Bulletproof, but not robotproof
I believe the lexan being referred to is the top section of the ball grabber, which is sticking at an angle upwards.
There was one match at Sacramento in which there was one ten point ball in each goal.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 21-03-2004, 22:15
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Yea .. it was the upper piece of the claw. If you look closely at the picture, you can see the piece of Lexan bent WAY up.
What happened, was when we drilled the holes for the spacers, the lexan cracked a little (little being less than 1cm long). It worked flawlessly for over a month, then it decided to kick the bucket at the competition. Lovely. Thanks again to Team 599, who provided us with a piece of lexan large enough to make another claw piece.
Heres a better picture of the damage:
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
pic: Team PIC of 354 Westinghouse HS CD47-Bot Robot Showcase 4 29-02-2004 12:15
pic: Lexan + Heatgun = CD47-Bot Robot Showcase 4 21-02-2004 00:19
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
