Re: pic: 222 3 speed closeup/cutaway
Thanks for all the complements and questions. We are always around in the pits too for specific detail. Brad is geting good at explaining these. As for the pushing... I was instructed specificly not to push anyone, just to accomplish the task at hand. We do tip, but I have not tipped since practice rounds, note they are practice rounds. I was trying new stuff. I also only ran away in first gear, because well, I am stupid, no, um, i just didn't shift up Figured we were going to the step to climb. It didn't matter when I got there so why risk hitting the corner of the stairs? BUt I will break out second gear some more if anyone wishes to see it. We ran our auton in second and I occasionaly jumped up when making the drive for a distance. Plus, balls +any other gear than 1st = bad, most of the time. We don't run up on them a lot with our lexan teeth but they get bent. So I avaoid higher gears and balls. BAD!!. Anyway, don't worry out there in Philly 11, I will show some more of our machine's capabilities. Annapolis was just a warm up . As Cliff has said. We've got some stuff up our sleeves...Last edited by henryBsick : 03-24-2004 at 06:19 PM. |
amazing design.
We are rookies trying to build stuff in the offseason (yeah for us the offseason has already started and that sucks). Anyway, is the only thing keeping the gears from lateral movement along the axle the pressure from the sides, or it there a locking mechanism? Wouldnt the friction of the gears touching reduce efficiency? Also, any generic advice on building trannys would be great. We have limited machining capabilities (no high tech stuff i.e. CNC etc.). |
Another good and simple gearbox is team 33's 4-speed automatic gearbox this year. I don't know that there is a white paper available for it, but you might be able to get a lot of information from them about it. It supposedly can be made with a lathe and a drill press with an X-Y table. Just some suggestions. There are tons of designs out there, as you can see by the variety just this year. A lot of it sometimes depends on the game. Good luck with your offseason work! |
I am planning to build one of your transmissions in the off-season, and hopefully develop an automatic shift algorithm for it, which of course I will share on this discussion board. I have a few (actually, several) questions on your design:
Sorry to have so many questions, but I am quite interested in this design you have some up with, and want to experiment with it. I think it shows great promise for future development. |
| pic: 716 Dual Motor/Dual Speed | CD47-Bot | Robot Showcase | 18 | 04-23-2004 01:51 AM |
| pic: 222 3 speed on the robot | CD47-Bot | Robot Showcase | 6 | 03-11-2004 09:39 PM |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 10-07-2003 03:04 PM |
| pic: 716 single speed | CD47-Bot | Extra Discussion | 2 | 09-09-2003 03:51 PM |
