Go to Post The size, speed, and power of full sized FRC robots are much more sublime. People go to the zoo to see the lions and tigers, not the ants. - Jared Russell [more]
Unread 03-25-2004, 09:01 AM
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: pic: 222 3 speed closeup/cutaway
I am planning to build one of your transmissions in the off-season, and hopefully develop an automatic shift algorithm for it, which of course I will share on this discussion board. I have a few (actually, several) questions on your design:
  1. It looks like you have used a fairly thick walled 1" diameter tube as the main axle. Was this machined out of a 1" rod?
  2. What material did you use?
  3. What diameter is the inside hole?
  4. How far out to the 5/16" ball bearings protrude when they are pushed out by the inner ring?
  5. Do you need to have two sizes of holes on the axle to prevent the balls from going in too far? Could you not just have the balls drop down and touch the spring?
  6. Does the shifter rod rotate with the axle, and if so, how do you push or pull on it?
  7. It seems that the balls might have a tendency to push themselves out due to the rotation of the axle, or at least drop down into a lower notch in a gear when the axle is at rest due to gravity. Do you have any problem with the balls coming out prematurely into the wrong gear?
  8. How much force is needed to push the shifter ring against a set of balls to select the next gear?
Sorry to have so many questions, but I am quite interested in this design you have some up with, and want to experiment with it. I think it shows great promise for future development.
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 04-23-2004 01:51 AM
pic: 222 3 speed on the robot CD47-Bot Robot Showcase 6 03-11-2004 09:39 PM
pic: dual speed gearbox CD47-Bot Extra Discussion 9 10-07-2003 03:04 PM
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 03:51 PM
