Go to Post Unless your HS students have earned BSEE and BSME degreees already, how can they lead or run an engineering team? - KenWittlief [more]
Unread 26-03-2004, 01:19
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: Team Hammond 2
Unread 26-03-2004, 01:54
mzitz2k's Avatar
mzitz2k mzitz2k is offline
Robotics Fiend
AKA: Matt Zitzmann
None #0302 (Mechanical Dragons)
Team Role: Student
mzitz2k will become famous soon enoughmzitz2k will become famous soon enough
Send a message via AIM to mzitz2k
Finally... Beatty 2004
Alrighty guys... we've finally got the treat of the year (at 1:20 AM)... Beatty reveals their bot! Can anyone say "crazy amount of actuation" three times fast?
I am not at the Midwest Regional, but here are my observations from the three pictures currently released. I see a drivetrain, 30" ball grabber, goal grabber, arm mechanism for grabbing the bar, stair climber, and a funnel for the ball release system.
It looks as though they have a double pneumatic system with cams, notice the right hand wheels with the little "guards" over them, to lift themselves up and onto the platform. The arm that latches onto the bar is mighty high too. I cannot figure, yet, what the two cylinders do that are mounted (somewhat) horizontally in the picture. I'm guessing the chiaphua motors are being hidden behind the wheel guards because I do not see them anywhere else. The Van door motor is being used to rotate the 30" ball grabbing arm and it appears that a pneumatic cylinder is used to actually open/close the ball grabber. This mechanism is identical to 2001's except for the flattened "paddles" at the end of the ball grabbing arm. The globe is used to rotate the bar grabbing arm. It looks like there is a spectra line or some sort of cable that runs vertically from a spool in the base to the bar grabbing arm.
I'm not sure how the whole funnel system works yet. You can see the "71" sticker pointing to the right, which implies that it is on some plastic. So, some how those balls roll out of the funnel and into that holding tank with the plastic. Is it possible the funnel arms are not actuated? I do not see any motors for this process.
More info... I see a fisher price motor and tranny feeding into that spool system for the extending bar grabber. I believe the two cylinders in the back are to help them for getting up the platform.
Recap:
(1) Drive train: Drill motors, with two cylinders mounted vertically to lift the front wheels. Two cylinders mounted horizontally to lift the back end (?). Chiaphua's are not being used or they are hidden.
(2) Goal Grabber
(3) 30" Ball grabber: Van door rotates the arm and a pneumatic opens/closes the arm
(4) Funnel system: Appears to have no actuation. Plastic guides balls down.
(5) Bar grabbing arm: Globe motor powers the rotation and a fisher price w/ tranny extends the arm.
My biggest question right now: How fast can they position under the ball release system? If they cannot complete this fast, then the balls will fall before they can get under it. Look at the way the funnel is - perpendicular to the direction of their wheels. This means they need a few seconds to position under the ball release. This is just speculation and I shouldn't even speculate like this with Beatty, but this is just a thought!
Okay, good luck guys tomorrow. It looks like we have a Beast of robot on our hands. Good night.
Matt
Team 302 - "The Mechanical Dragons"
Engineering Inspiration Award - Western Michigan Regional (2004)
Division Champions - Newton Division (2003)
Regional Champions - Great Lakes Regional (2003)
General Motors Industrial Design Award - Great Lakes Regional (2002)
Motorola Quality Award - Buckeye Regional (2002)
Regional Finalists - Buckeye Regional (2002)
Division Finalists - Newton Division (2001)
Regional Finalists - West Michigan Regional (2001)
Unread 26-03-2004, 01:56
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Re: pic: Team Hammond 2
Okay... *phew* here we go.
My analysis of the 3 71 pictures.
Drivetrain:
4WD. 4 independant gearboxes. (Shocking.) 2 look like Drills. I'm guessing the other 2 are Chiaphuas.
Goal Capper:
No surprises here. 2 PVC arms with what looks like sorbothane on the tips for grabbing the big ball. This mechanism looks familiar.
Hanging Arm:
A long extending PVC arm with a hook on the end. Powered down by what looks like a cable running into the base. Some sort of winch?
Step Climbers:
The "Rear" wheels are pneumatically actuated up and down. Pretty slick looking.
Ball Catcher:
Note the teflon on the side of the robot facing us?
I assume that means... the robot starts sideways, with this against the wall, and drives to the center of the ball drop (sliding the side along the wall). Then, the hanging arm, and the capping arm both flip out, along with those other 2 flaps... The arms must have some netting or something which isn't on there right now. From there the balls are funnelled into a lexan tube which runs through the center of the robot. (only parts of it are visible in the picture? This one baffled me for a little while). Then, once the balls are in it, it drives back along the wall to the HP and deposits them.
JVN Stumpers:
Those 2 suspicious looking pneumatic cylinders in the center of the robot base. (On the left side of the picture). What do you suppose those do? I think they will keep me up at night. Possibly powering the winch somehow? Hmmm....
Overall, I'm very impressed. This is just my interpretation of these pictures, and I suppose we'll have to wait until tomorrow to know for sure. I will certainly be watching....
Kudos to 71... another great season in the making.
I'm Inspired,
JVN
Unread 26-03-2004, 02:32
Amanda Morrison's Avatar Unsung FIRST Hero
Amanda Morrison Amanda Morrison is offline
16 awesome years of FRC!
Amanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond repute
I knew we couldn't expect anything less. Here's to looking at another successful season.
But I can claim that kid in on the right hand side of the picture with the duct tape shoes (unfortunately...) Meet Andrew Morrison.
Director of Operations, VEX Robotics, Inc.
Alumna - Teams 71, 1020, 1720, 148
2002 World Champions (Team 71) | 2008 World Champions (Team 148)
Unread 26-03-2004, 09:41
Craig's Avatar
Craig Craig is offline
Drive it like YOU BUILT IT!
FRC #4976 (REBELS!)
Craig is an unknown quantity at this point
Wow, that robot brings new meaning to word multi-tasking! Nice Job!
I'm thinking the two more or less horizontal cylinders actuate a gate to release the balls to the ball corall. Its difficult to see but all that plastic is like a big funnel that ends right at those cylinders. Anyone have any idea how they telescope the hanging arm??? I'm fascinated with telescoping mechanisms but I cant even guess at how they do it.
Good luck in comp today
Unread 26-03-2004, 23:42
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Originally Posted by JVN
JVN Stumpers:
JVN
How about mobile goal hooks?
Ryan
FRC/FLL volunteer since 2005
Unread 27-03-2004, 00:16
mzitz2k's Avatar
Robotics Fiend
AKA: Matt Zitzmann
Team Role: Student
Two cylinders that size would be over kill for just grabbing the mobile goal. And, the same goes for opening and closing their ball collector. The telescopic arm uses spectra cable with a fisher price motor. I am not sure exactly how they pulled off the telescopic arm, but I am sure it is very similar to last year's arm.
302 wishes everyone good luck at the Midwest Regional.
Matt
Unread 27-03-2004, 00:19
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
I like the part how they can cap like 782. If you saw the web-stream they can deploy the hook and capping the goal from the back of it at the same time. Very slick looking machine.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 27-03-2004, 11:02
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
interesting the built their frame so low to the ground to be able to drive around with the ball so quickly....the next question would be how are they getting up on the platform so quickly? if someone from team hammond, or someone @ chicago could tell me I would be very appreciative...
Unread 28-03-2004, 00:55
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
alright guys. just back from midwest regional. beatty was a decent robot even though we beat them in the semis. they never did position under the ball release. they did pick up the 2x ball very well. they can hang well too. also, they can cap while hanging. not a very good control of the robot. easy to stop from hanging. hang from 1st platform. that's about all i have.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
