Go to Post What is this, presto change-o rules every week? - Racer26 [more]
Unread 30-03-2004, 11:30
Re: pic: YMTC: Is 41 hanging?
Joe Ross has a good point - the rules as written are already lenient and forgiving - if a part falls off your bot completely (say a piece of foam bumper somewhere on the field) it could be agrued that your bot is not 'hanging' because of piece of it is lying on the floor in the middle of the field - therefor your WHOLE bot is not hanging - but the rules do not go to that extreem
the reason the bot in the photo is not hanging is the belt is part of the bot and its supported by the floor - that part is broken though, right? ok - so what if an arm broke and was supported by the floor? what if a cable broke on one side and two wheels were in the air and two were on the floor - you could argue that if the bot was lifted high enough the remaining cable would support it
but that IS the nature of the challege - to get your WHOLE bot up in the air, not just the working parts, the broken parts too - if its still attached then no hang.
BTW something similar happened last year - a team put a little flag on their bot so they could see it on the other side of the ramp - at the end of the match the bot was ontop of the ramp, but the little flag was drooped over and touching the top of the side railing - no 50 points for them either.
YMTC: Bluabot and Redabot hanging? Natchez You Make The Call 15 23-03-2004 01:42
pic: Four Hanging CD47-Bot Extra Discussion 6 14-03-2004 15:52
pic: Team 48 Robot Hanging CD47-Bot Robot Showcase 1 01-03-2004 20:22
pic: rotory walker robot hanging CD47-Bot Robot Showcase 1 24-02-2004 08:06
pic: rotary walker side hanging CD47-Bot Robot Showcase 2 23-02-2004 12:29
