Alternative to servos?
On another note, how does the CIM work? We built a transmission over the summer, where the CIM was drawing huge amounts of power, and ended up for this year with something similar to the two motor design in the white papers. Does a single CIM work? And if so, doesn't manual shifting get confusing during a fast paced match? Back to the earlier SCS thing. It might be possible to design a "steptronic" type control that normally shifts automatically, but could be overidden for climbing, &c. Last edited by CJO : 04-05-2004 at 04:18 PM. Reason: show signature, it wasn't there |
Re: Alternative to servos?
Have to check on the rotary pneum.'s thanks for the idea. Yes, it probably is possible to shift with a servo but we wanted to get away from them. We had troubles on the drill transmisions with the number being in the right spot to tell the servos where to stop. They worked every match but they occasionaly caused us grief. We checked the power curve for the CIM's to figure in on a good ratio. I drive it and it isn't bad. I shoot over some where quickly and then just get into a lower gear to push, pull, climb. It really isn't bad. I was talking to our programmer about adding a new switch and a current sensor to make it auto. We might we might not. It isn't really neccesary for this game to much.(for us anyway). But back ont to topic, no it isn't hard on the driver (me). I am lost with the whole SCS thing since I saw the first post about it. -Henry Last edited by henryBsick : 04-04-2004 at 08:07 PM. |
Re: SCS
Re: SCS
Re: pic: 222 3 speed closeup/cutaway
I see now. Thankyou. There would be two set of sensors, and they would match rpm of the input shaft to that of the output shaft. Great system but I see one probem with that. The shift wouldn't be exactly insantaneous, it would wait for shaft speed to = then shift. If a robust enough tranny is built i see no need for the matching of speeds, other than smooth shifting. Ours now is pretty smooth though thanks to the springs on the shifting rod. I have slammed it from 3rd into 1st many times (just to make sure) and it has skidded, I wasn't on carpet all the time, but it could take the throw of the ratio change. I still like both ideas though . / thinks to self/ there is an offseason for a purpose /done thinking/ |
/Learns more and more each day. / |
Team 254 used the same sensors on their drive shafts this year as are used on cnc mills to determine table position (I forget what they're called)
~Christopher |
#11
It would be cool to have an automatic shifter but I do not see the need for it.
I doubt a servo would last very long if it were used with our trannies. If it was stalled while the holes were not aligned it might hurt the little motors. The servos would also require very accurate maching methods for the shift rod and also require very good programing to align the shifting rod with the ball bearings. However a servo could probably handle the job. |
| pic: 716 Dual Motor/Dual Speed | CD47-Bot | Robot Showcase | 18 | 04-23-2004 01:51 AM |
| pic: 222 3 speed on the robot | CD47-Bot | Robot Showcase | 6 | 03-11-2004 09:39 PM |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 10-07-2003 03:04 PM |
| pic: 716 single speed | CD47-Bot | Extra Discussion | 2 | 09-09-2003 03:51 PM |
