Go to Post After all, bitterness takes all the fun out of wiring. - Venkatesh [more]
Unread 04-05-2004, 04:42 PM
henryBsick's Avatar
henryBsick henryBsick is online now
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: SCS
Originally Posted by CJO
Correct me if I'm wrong, somebody, but I thik the whole SCS thing was to add sensors to the transmission so that the computer would keep it in the most advantageous gear at all times, similar to the transmissions on most cars.
I understand that something would be done to monitor the rpm's or another measurable function that would contribute to the horsepower. They would then shift up/down to get max. horsepower. The only thing was the specifics of the sensor. Where to put, what kind etc.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 04-05-2004, 07:35 PM
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: pic: 222 3 speed closeup/cutaway
The SCS was to be able to synchronize the gear and shaft. Automatic transmissions already put it into the most advantageous gear at all times. The SCS would lower or increase the power to the motors so that the gear selecting shaft would be running at the same speed as the next gear it is about to select prior to actually engaging the gear. It would cause less stress on all the components and give you smoother shifts.
See you in DC!
Unread 04-05-2004, 08:17 PM
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
I see now. Thankyou. There would be two set of sensors, and they would match rpm of the input shaft to that of the output shaft.
Great system but I see one probem with that. The shift wouldn't be exactly insantaneous, it would wait for shaft speed to = then shift. If a robust enough tranny is built i see no need for the matching of speeds, other than smooth shifting. Ours now is pretty smooth though thanks to the springs on the shifting rod. I have slammed it from 3rd into 1st many times (just to make sure) and it has skidded, I wasn't on carpet all the time, but it could take the throw of the ratio change. I still like both ideas though . / thinks to self/ there is an offseason for a purpose /done thinking/
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 04-06-2004, 10:15 PM
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
That is a very good thought, but without any load on the motors, the speeds would match very quickly and it would still shift rather quickly.
See you in DC!
Unread 04-06-2004, 10:20 PM
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Yeah, oops, forgot about the neutral positions. It would require servos or some other sort of multi psitioning shifter instead of our 1,2,3 pneumatics.
/Learns more and more each day. /
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 04-06-2004, 10:30 PM
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
That is what FIRST is about!
See you in DC!
Unread 04-07-2004, 10:23 PM
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Team 254 used the same sensors on their drive shafts this year as are used on cnc mills to determine table position (I forget what they're called)
~Christopher
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 04-08-2004, 01:05 PM
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
It would be cool to have an automatic shifter but I do not see the need for it.
I doubt a servo would last very long if it were used with our trannies. If it was stalled while the holes were not aligned it might hurt the little motors. The servos would also require very accurate maching methods for the shift rod and also require very good programing to align the shifting rod with the ball bearings.
However a servo could probably handle the job.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 04-23-2004 01:51 AM
pic: 222 3 speed on the robot CD47-Bot Robot Showcase 6 03-11-2004 09:39 PM
pic: dual speed gearbox CD47-Bot Extra Discussion 9 10-07-2003 03:04 PM
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 03:51 PM
