Go to Post Crushing the box makes it much easier to think outside the box. :D - Matt C [more]
Unread 05-04-2004, 17:11
David Bridge's Avatar
David Bridge David Bridge is offline
Totally Sweet... Man
FRC #0177 (Bobcat Robotics)
David Bridge will become famous soon enoughDavid Bridge will become famous soon enough
Send a message via AIM to David Bridge
Re: pic: Capping 177
Originally Posted by ZACH P.
Hey Evan, you obviously had a reliable ball delivery system for your net. Can you give me some detail on the working of it?
Im not evan, but can answer the question just as well... at the front of the robot we have a knurrled roller thats about 12 inches off the ground, it runs the full width of the robot (about 2.5 balls worth)... The roller is run by a globe motor that has had one set of planetary gears taken out to give us the speed and power that we wanted. The motor is actually anchored inside of the roller so it gives us a direct drive with no loss of power, but at the same time doesnt take up much additional space. In the hopper itself there is a conveyor made of polycord which is run by a geared vandoor motor to keep the balls from jamming... This system results in excellent performance picking up and delivering the balls
pic: Panoramic Pic from Nationals 2001 CD47-Bot Extra Discussion 19 23-03-2004 23:38
pic: GM & Simbotics, 1114 -- Simon Capping A Goal CD47-Bot Robot Showcase 11 18-03-2004 15:27
pic: Capping a Robot CD47-Bot Extra Discussion 16 17-03-2004 20:28
pic: Capping a Robot CD47-Bot Extra Discussion 2 17-03-2004 10:17
