Re: pic: 222 3 speed closeup/cutaway
I see now. Thankyou. There would be two set of sensors, and they would match rpm of the input shaft to that of the output shaft. Great system but I see one probem with that. The shift wouldn't be exactly insantaneous, it would wait for shaft speed to = then shift. If a robust enough tranny is built i see no need for the matching of speeds, other than smooth shifting. Ours now is pretty smooth though thanks to the springs on the shifting rod. I have slammed it from 3rd into 1st many times (just to make sure) and it has skidded, I wasn't on carpet all the time, but it could take the throw of the ratio change. I still like both ideas though . / thinks to self/ there is an offseason for a purpose /done thinking/ |
/Learns more and more each day. / |
Team 254 used the same sensors on their drive shafts this year as are used on cnc mills to determine table position (I forget what they're called)
~Christopher |
It would be cool to have an automatic shifter but I do not see the need for it.
I doubt a servo would last very long if it were used with our trannies. If it was stalled while the holes were not aligned it might hurt the little motors. The servos would also require very accurate maching methods for the shift rod and also require very good programing to align the shifting rod with the ball bearings. However a servo could probably handle the job. |
| pic: 716 Dual Motor/Dual Speed | CD47-Bot | Robot Showcase | 18 | 04-23-2004 01:51 AM |
| pic: 222 3 speed on the robot | CD47-Bot | Robot Showcase | 6 | 03-11-2004 09:39 PM |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 10-07-2003 03:04 PM |
| pic: 716 single speed | CD47-Bot | Extra Discussion | 2 | 09-09-2003 03:51 PM |
