Go to Post Code doesn't break. It reacts exactly the same time every time. When something new happens that never happened before, it's because the mechanicals, electricals or drivers gave the code some new stimulus that wasn't tested before. - GaryVoshol [more]
Unread 09-04-2004, 09:43
Dennis Jenks Dennis Jenks is offline
It's good to be home.
FRC #0254
Dennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud of
Re: pic: 254 Drivetrain
Originally Posted by Natchez
How do you cap the screws? Do you countersink them? We tried all kinds of things last year but we could never convince ourselves that we weren't violating the "Traction devices may not have surface features such as metal" rule. Plastic fasteners were not as good as glue. Of course, that's not what the four students that went around with their fingers stuck together for two weeks thought.
Thanks for the help,
Lucien
If you look at the wheels you can see that they are of two piece construction. Each side has a small lip on it so that when they are sandwiched together they grip the tread and keep it in place. The wheels are tapped and we use a pair of small pan head screws, not to hold the tread down but simply to keep the tread pulled tight. These are positioned so that they sit in the waffle well below the tread. If you are using screws to physically hold the tread down then you would need to use a larger head which may not sit deep enough to pass inspection.
Dennis Jenks
FIRST Team 254 Mentor
pic: team 254 teaser CD47-Bot Robot Showcase 10 02-03-2004 10:06
pic: team 254 teaser CD47-Bot Robot Showcase 4 07-02-2004 09:37
pic: Team #461 Drivetrain CD47-Bot Robot Showcase 8 05-03-2003 08:07
pic: Team 254 Robot Cart (1 of 3) CD47-Bot Extra Discussion 3 28-02-2003 16:51
254 The Best Partner in FIRST sfield Regional Competitions 5 03-04-2002 23:23
