Go to Post There is beauty in pure simplicity. - artdutra04 [more]
Unread 13-04-2004, 01:01
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: White Paper Discuss: Karthik's Championship Event Data
Originally Posted by 10intheCrunch
Ummm, OK I was looking over it again, and...are you sure you got the standard deviations right? There are several SDs that are greater than the mean score, which seems to ring wrong with me (I haven't taken stats but +- 1 SD is about 2/3 of the data, right?).
The standard deviation is only 2/3 of the data when the data is gaussian (also called normal or bell shaped curve). The score's of most team's matches is no where near a bell shaped curve, and so that doesn't hold. I checked the numbers for team 970 at OH, which was one of the teams where the standard deviation was higher then the mean, and the calculations were correct.
(standard deviation)^2 = (sum(xn - mean)^2)/(n-1)
You can use this webpage to do the calculations for you: http://www.physics.csbsju.edu/stats/...NROW_form.html and this page has explanations of a bunch of different statistical measurments: http://www.physics.csbsju.edu/stats/descriptive2.html
White Paper Discuss: All I Ever Needed to Know I learned in FIRST poster CD47-Bot Extra Discussion 5 28-03-2005 15:44
White Paper Discuss: 2004 Visual Basic 6 Dashboard Control CD47-Bot Extra Discussion 2 01-02-2005 01:56
White Paper Discuss: Interrupts for Dummies CD47-Bot Extra Discussion 5 29-01-2005 03:24
White Paper Discuss: Use of Gyros in Navigation, Tip Prevention, and Driver Control CD47-Bot Extra Discussion 1 18-03-2004 08:36
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
