Go to Post what is FIRST?...It's about innovation, hard work, inspiration, teaching, learning, experiment, strategy, competition, meeting new people, being inspired, aiming high and changing paradigms...Really, FIRST is what you make of it. - jarowe [more]
Unread 15-04-2004, 11:27
JessR JessR is offline
#0571 (Team Paragon)
JessR will become famous soon enough
Re: pic: 571's new gearz loose weight
Originally Posted by sanddrag
How are the white plastic gears affixed to the shaft on which they lie? Thanks.
Planned: Key and setscrew for each of the 4 plastic gears.
We expected gears as plastic with a metal bushing in the hub large enough to bore & modify. Well, the gears we got in time for ship date were different from plan, so we had to improvise a bit.
Actual:
- The Mod .7 metric gear (meshes with Bosch drill motor) is all plastic, so it has just a key with no set screw. This worked out fine, with the gear hub covered at both faces, the key is captured & can't come out the end of the hub.
- The other 3 plastic gears, I think 32 DP, (meshes with Fischer Price motor) are mixed - have either key and setscrew, or just setscrew.
2004 UTC New England Champions with 716 & 230
Engineering Lead
Team Paragon #571
pic: last minute weight loss CD47-Bot Robot Showcase 11 26-02-2004 19:41
pic: last minute weight loss CD47-Bot Robot Showcase 6 26-02-2004 01:17
pic: Team 1156 - Weight Measure CD47-Bot Robot Showcase 5 25-02-2004 23:50
pic: 571 2004 new gearz.. CD47-Bot Robot Showcase 7 22-02-2004 20:10
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
