Go to Post "Individual": I am the FMS. I don't want to talk to you. Robot: FMS, is this true? I still have stuff for you. Actual FMS: No, what gave you that idea? Are you feeling ok? Repeat. Field Monitor: FTA! We need a counselor! - EricVanWyk [more]
Unread 15-04-2004, 12:09
Re: pic: 571's new gearz loose weight
Originally Posted by JessR
Actual:
- The Mod .7 metric gear (meshes with Bosch drill motor) is all plastic, so it has just a key with no set screw. This worked out fine, with the gear hub covered at both faces, the key is captured & can't come out the end of the hub.
What size bore, keyway, and length through bore? If I could just get those three things that would be great. Thanks.
pic: last minute weight loss CD47-Bot Robot Showcase 11 26-02-2004 19:41
pic: last minute weight loss CD47-Bot Robot Showcase 6 26-02-2004 01:17
pic: Team 1156 - Weight Measure CD47-Bot Robot Showcase 5 25-02-2004 23:50
pic: 571 2004 new gearz.. CD47-Bot Robot Showcase 7 22-02-2004 20:10
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
