Go to Post One of the many unwritten laws of engineering failure is that the problem will occur in the most inopportune time. - Dave Scheck [more]
Unread 18-04-2004, 23:29
Engineering Mentor
FRC #0254
Re: pic: 254 Drivetrain
Originally Posted by Stephen Kowski
I'm wondering how 60/254 packed their solenoids together sooo tight.....is there room for the hose/fittings....can anyone elaborate...?
It is a SMC solenoid manifold. It is available through any SMC distributor (Motion industries etc). It has a common pressure input, and has ports for the solenoids on top and quick disconnect fittngs on the side, 2 for each solenoid. Block off plates are available if you decide to remove a solenoid or cannot purchase a small enough manifold. (in our case we needed ports for 7 solenoids, and thus had to purchase an 8 port manifold, we blocked off the 8th port) I think they come in manifolds of 2 and larger (maybe 4, I can't remember) and I recall them being in multiples of 2.
Hope that helps!
-Travis Covington
pic: team 254 teaser CD47-Bot Robot Showcase 10 02-03-2004 10:06
pic: team 254 teaser CD47-Bot Robot Showcase 4 07-02-2004 09:37
pic: Team #461 Drivetrain CD47-Bot Robot Showcase 8 05-03-2003 08:07
pic: Team 254 Robot Cart (1 of 3) CD47-Bot Extra Discussion 3 28-02-2003 16:51
254 The Best Partner in FIRST sfield Regional Competitions 5 03-04-2002 23:23
