Go to Post The reason I care about it is that I don't want minorities (whether that's females or other racial minorities) to see the STEM world as only inclusive of majorities or men. - Monochron [more]
Unread 04-26-2004, 10:10 PM
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: 870 Motor Mount
Unread 04-26-2004, 10:12 PM
Tytus Gerrish's Avatar
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Re: pic: 870 Motor Mount
OHH look at all the CNC
Unread 04-26-2004, 10:14 PM
RBrandy RBrandy is offline
AKA: Ryan
#0093 (NEW Apple Corps)
RBrandy is a jewel in the roughRBrandy is a jewel in the roughRBrandy is a jewel in the rough
Send a message via AIM to RBrandy
Ive gotta question... Why is that chain so close to the floor? Did that cause any problems?
But nice mounts for the motors. Are those U-bolts the only thing holding it on to the rest of the robot?
Team 93 Alumini
Unread 04-26-2004, 10:23 PM
Greg Perkins's Avatar
7 years, allready!!???!?!?!
AKA: Mongo
the chain isnt even attached to the sprockets
Unread 04-26-2004, 10:25 PM
AKA: Ty
that could be a problem for a robot
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Ohh very nice, robust and compact, how did your drive fair for you this season?
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 04-27-2004, 09:34 AM
Toolman Toolman is offline
Coach
AKA: Tony
FRC #3171 (WHB/Hurricanes)
Toolman is an unknown quantity at this point
Wink Re: pic: 870 Motor Mount
Ok All! Now that you have a look at the drives lets give you some pros and cons from our 870 drive system.
This complete drive system was manufactured on a cheap hand operated import $900 mill and NOT A CNC. This means if we can do it you can also with a basic mill. This is our best design and lightest weight thus far for using the drill drive set up.
Pros:
* The motors always ended up cooler at the end of a round than at the beginning due to great heat transfer/cooling.
* The mount is held totally in place with one u-bolt allowing for fast removal if needed. ( We never had to remove or do any repairs to the drive system at the regional or Atlanta!)VERY DEPENDABLE
* The design allows for almost any orientation in a bot.
* The strength of the system supporting the drill transmission allows for extreme side load and end load if necessary.
* The design allows useing the threaded drill end if desired or if needed a custom shaft as we did can be machined to fit into the drill dogs.(that is another internal pic of the system)
* The design once removed from the bot requires removal of the six socket head bolts and splitting the bracket for fast drop in parts replacement.
Cons:
* Time to make one drive mount appx: 5hrs
* precise machining is a must( put your best millers on the task)
Unread 04-27-2004, 10:54 AM
MOEmaniac's Avatar
MOEmaniac MOEmaniac is offline
The Crazy One
AKA: Steve
FRC #0365 (MOE)
MOEmaniac has a spectacular aura aboutMOEmaniac has a spectacular aura about
Send a message via AIM to MOEmaniac Send a message via Yahoo to MOEmaniac
ooooooooooooooooohhhhhhhhhhhhhhh aaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhh their perty lol
how much did they weigh?
When logic fails, force prevails!
2005 Record
Pittsburgh Regional: #1 seeded, Finalist - Thanks teams 808 and 869, Entrepreneurship Award, Sportsmanship Award, Website Award
Philly Regional: #2 seeded, Champions - Thanks teams 56 and 316, WFA Lou Rosanio, Chairmans Award
Nationals: Still to come
2004 Record
New Jersey Regional: Quarterfinalists - Thanks teams 25 and 103, Judges Award
Philly Regional: Quarterfinalists - Thanks teams 1370 and 1143, Imagery Award, Website Award, WFA Joe Perrito
Nationals: Galileo Finalists - Thanks teams 177 and 27, National Imagery Award
Unread 04-27-2004, 11:12 AM
Coach
AKA: Tony
The mount incorporating only the aluminum portion is .7lbs .
( This is the lightest ever!
just add the six socket head bolts and it will still be under 1 lb
Unread 04-27-2004, 11:55 AM
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Originally Posted by Toolman
The mount incorporating only the aluminum portion is only .
70lbs. This is the lightest ever!
Maybe edit so that it says: .70 lbs instead of .
70 lbs.
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 02-16-2004 10:56 PM
pic: Team 870 Suction Cups CD47-Bot Robot Showcase 45 03-29-2003 10:48 PM
pic: Team 870 Wiring Nightmare CD47-Bot Robot Showcase 15 03-02-2003 09:46 PM
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 02-27-2003 03:23 PM
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 02-27-2003 12:22 AM
