Go to Post It made me proud to know that we have corporate sponsors with genuine interest. - galewind [more]
Unread 27-04-2004, 15:37
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: Torque Converter
Unread 27-04-2004, 15:41
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Re: pic: Torque Converter
So there is some sort of belt that runs between the two spools. How are you shifting? Is the green thing a tensioner?
This is a very interesting idea, can you give us an idea of exactly how this is going to work?
Unread 27-04-2004, 15:47
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Im going to attempt to describe how this works in words...bear with me. I'm not sure how familar you are with a snowmobile transmission works but this is on variation of it. What I've done is have the motor spin the cone shaped object. This cone will spin a timing belt. and depending on the power needed by the robot the belt will slide up and down the cone. The spool shaped object is the output shaft to the wheel/track/etc. This whole system works of the tension of the springs and the belt and is mechanically automatic. The green thing is the tensioner on the belt. Currently this is my last ratio only because I don't believe a belt could handle the high RPM of the atwoods(my team only uses the atwoods in the drivetrain).
Please keep the questions coming...
-Thanks
Pat
*edit*there are some more design views being uploaded soon*edit*
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 27-04-2004, 15:49
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
This is called a CVT (continuely variable transmission), a torque converter uses hydrolic forces to chagne torque in automatic transmissions.
there are designs all over these forums of them! Yours looks nice though!
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 27-04-2004, 16:02
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Strangely enough, they also call snowmobile-type CVTs "torque converters". I was also very confused at this the first time I heard it. Someone on my team asked me, "why don't we use a torque converter for the transmission?"
I said, "because we would lose power because to fluid coupling is not very efficient."
Then we both thought each other were idiots for a little while. Little did I know that these CVTs were called "torque converters" and the other guy didn't know that the fluid coupler in an automatic transmission was also called a "torque converter".
Anyway, the point of the story is that they both share the same name.
An ounce of perception is worth a pound of obscure.
Unread 27-04-2004, 17:45
Mechanical Engineer
I plan to make a white paper if I can test it and whatnot. I also will have some more detailed drawings eventually. Can anybody see any problems with the current one (other than theres no motor)
-Thanks
Pat
2010 and Beyond
Unread 27-04-2004, 18:38
What keeps the belt from slipping. Does just the friction keep the spool and cone in sync? Also, what would be the efficiency of a contraption like this?
Unread 27-04-2004, 18:44
Mechanical Engineer
Thats correct that the friction of the belt and cone cause the spinning action. The spool looking object will be a timing pulley and will have teeth. As for the efficiency not sure havent done any testing.
-Pat
2010 and Beyond
Unread 27-04-2004, 19:54
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
How do you keep tension in the belt when it slides down to the right side where it is smaller?
Penn Class 08
Unread 27-04-2004, 20:09
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
If this device is actually built like a mini torque converter from a snowmobile (I'm from northern Canada and have three snowmobiles, and the assemblies in them don't look the same.) then it will have very low efficiency, especially with an electric motor. Because the Troque converter in a snowmobile uses high RPMs to shift the belt ou farther and gain a higher ratio. The faster the motor spins the more torque you get. This is fine for a gas engine that is designed where the maximum torque output is very close to the redline RPM, but in an electric engine the max torque is a 0 RPM, so it would be impossible to get even close to your maximum torque out of a that sort of design with an electric engine.
Then again I have lots of snow machines, and spend most of my free time fixing snowmobiles, and that device doesn't look the same as whats under the hood of my Mach Z.
Unread 27-04-2004, 20:15
NoRemorse's Avatar
AKA: Brian Roberts
here is a pic of team 494's cvt, using 2 cones to control the ratio. much better than one in my opinion.
Unread 27-04-2004, 20:23
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
noremorse, how does the ratio changing happen? I can't see how the timing belt can move anywhere or how either of the pulleys change size unless maybe the two halfs of the cones move closer to each other...
Team 1257
Mechanical Engineer
The tensioner is on a spring it constantly is having a force acting on it to create tension.
-Pat
2010 and Beyond
Unread 27-04-2004, 20:27
NoRemorse's Avatar
AKA: Brian Roberts
The 2 cones move toward eachother, effectivly increasing the diameter of the conact area of the belt and cone. The other side does the opposite to componsate for tension.
Unread 27-04-2004, 20:40
Mechanical Engineer
Noremorse,
I see what your saying in why two is better. For simplicity though I thought that one would work. This is still obviously being developed. My next step is to get the details worked in and hopefully build a working model. I think that a problem that I may have to solve is increasing the distance between the two pulleys. Any comment on that?
-Pat
2010 and Beyond
torque converter _GP_ General Forum 8 06-02-2004 19:26
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
Traction Limited, rather than torque Simon G Technical Discussion 6 23-01-2002 07:08
