Go to Post You'll want to start with P, add some D to help prevent overshoot, and then add some I to help it get to the correct height if it isn't there from the P and D. - AustinSchuh [more]
Unread 17-06-2004, 09:24
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: pic: Failed attempt at simulation
Originally Posted by ToMMan b182
how do you throw the balls into the goals?
Well, you don't! The robot actually did have a mechanism for it, but this is a much scaled back version I used for debugging purposes because it loaded much quicker. The physics support in CS was just beginning at that time, though, and there were quite a few glitches. Trying to move a ball with the robot created an inconsistent system, and all sorts of wierd things happened. I was in almost constant contact with the mailing list, and actually convinced someone to start working on ODE support ... but it didn't come quick enough for my project (and I don't know where it is now, this was 2 years ago).
pic: Panoramic Pic from Nationals 2001 CD47-Bot Extra Discussion 19 23-03-2004 23:38
pic: Team PIC of 354 Westinghouse HS CD47-Bot Robot Showcase 4 29-02-2004 12:15
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
Team #237 2001 Robot - "Nineteen foot six" archiver 2001 13 24-06-2002 00:59
