Go to Post Suggesting change is one thing, implementing it is another. - JaneYoung [more]
Unread 17-07-2004, 13:35
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
pic: FIRST veterans knowledge needed. What kind of motors are these?
Unread 17-07-2004, 13:38
Re: pic: FIRST veterans knowledge needed. What kind of motors are these?
The two on the left I believe are the small Johnson Electric motors. I think we got one in the kit each year through 2002. I have never seen one used on a robot. I'm guessing the third one from the left is an older year Johnson Electric motor. And the far right is a Fisher Price, can't tell on the year though.
Unread 17-07-2004, 13:45
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
You can tell between the current and last years FP motors by looking at the fan through the vent holes. It might be hard if you don't have two to compare or haven't done this check before, but last year's motor had square edged fan blades while this year's has chamfered edges. The fan blades on last year's are also slightly darker. Like I said before, it helps to compare to a current one.
Team 1257
Unread 17-07-2004, 14:54
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
I believe the motor to the far left was called the Mitsubishi motor. It was included in the 2002 kit of parts, but then dropped because they were useless.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 17-07-2004, 15:11
I think you mean Mabuchi. Yes, I remember a really small one called the Johnson ad another really small one called the Mabuchi.
Unread 17-07-2004, 15:21
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
if i remember right the Johnson motor was like an orange block that had a single output shaft on it and the motor kinda built into the block. Ill try to dig up photos and see what i fiind...
[edit]ok so i checked around and did some research and the orange box that i was thinking of is the Belimo "torgue" motor. All i have found on the Johnson electric motors is that are 40 watt motors. Elgin are there any ratings on the motors you have pictured. [/edit]
[edit 2] ok so i finally have completed going through all 15 pages of threads in the motor forum and i found one post by Dr. Joe (thanks alot) from 2 years ago that he posted the spec sheets for the 2002 Johnson motor on. That thread is here. I hope this helps somewhat. [/edit 2]
[edit 3] ok on the last page all the way near the bottom Dr. Joe also had 2 threads that were about the mabuchi motor. This One shows a motor spec sheet for that motor, while This one was between Dr. Joe and Paul Copioli about how the Mabuchi motor might just be the same as the fisher price motor. [/edit 3]
-Michael Dessingue
Unread 17-07-2004, 17:19
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
I believe:
We got a small Johnson motor in the kit in 2002.
But...
The FP motor is actually a Johnson or Mabuchi motor (we've had both in the past). So when someone says "The Mabuchi motor" they could really be reffering to the FP.
I'm trying to think...
The FP from 2002 was a Mabuchi.
The FP from 2003 was a Johnson and it was MUCH more powerful than the previous Mabuchi.
The FP from 2004 was a Johnson, but it's specs were similar to the Mabuchi from 2002 and wasn't quite as powerful.
Any motor wizzes out there remember differently?
John
Unread 17-07-2004, 17:24
FIRST recently took the 2002 documents off their site. Too bad really.
Unread 17-07-2004, 18:36
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by CD47-Bot
Thread created automatically to discuss this image in the Picture Gallery.
Ok.. cool.. This helps a lot.
I have multiples of all of these motors, and some of them have the Mabuchi logo on them. Thanks for the Excel file Mike. I knew that logo looked familiar.
Anyways. I do have some numbers on these.
From left to right:
1) RS-360SH
RD426X30
(MABUCHI LOGO) CHINA
Think I found that motor on Mabuchi's website HERE
2) 883253 or 883243
(Some kind of logo is on the top-side near the output shaft and on the bottom near the slots for the leads.) I don't think it is a Mabuchi logo.
3) 38600
3A2342
4) 74440-0640
(Mabuchi Logo) TB071903
MADE IN CHINA
Ok.. Now I know what kind of motors these are, anybody know the stats on them? I'm assuming these are all 12 volt (DC?) motors??
Sorry for the questions, I am unfamilar with motors in general, I just know the ones we use nowadays.
I went to the Muabuchi website and did a product search, but none of these seem to be on there. Interesting..
Maybe they were retired and are no longer used by Mabuchi as well??
Unread 17-07-2004, 19:18
The far right seems to be the 2002 (Mabuchi) Fisher Price Motor, with the spec sheet here. Other then that i really couldnt give you some info off hand. What year "yard sale" did you get these from FIRST at.
-Michael Dessingue
Unread 18-07-2004, 01:50
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
Yeah, the good old days of Mitsubishi.
FIRST had another useless motor called the "Torque Motor" (i.e. It is probably an Indiana Ghetto-linguicized version of the Mitsubishi Motor). It had the torque of my left pinkie and made one rotation every 60 seconds when geared down. The motor, including the gear box, was the size of an altoids pack. The motor itself would make an RC look proud.
Back then (it was 2001, and I was a freshman then), the main "mechanics" advisor called it "Speedy", a fairly accurate name given the description above. I had an idea for it to lift a sign, starting from the beginning of the match, that said either "Go 461" or "Schlumberger, DePuy, Purdue University, WLCSC", etc. [sponsor's names]. Some of those motors, though, were before my time.
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
Unread 24-07-2004, 08:06
Originally Posted by Elgin Clock
4) 74440-0640
MADE IN CHINA
Ok, searching Google and finding THIS post by Paul Copioli and reading the info there lead me to find this website:
http://www.enigmaindustries.com/Moto...ight_45935.htm
Apparently that 4th motor was an old drill motor from the kit, but from a Harbor Freight Drill!?!?!
Anybody have info on the other two motors? Number 2 and 3?
Oh, btw.. Dez, I think it was the 2001 or 2002 FIRST Giveaway I got these at.
Can't remember.. Have to rack my brain and remember. lol
Unread 24-07-2004, 13:25
There are many Mabuchi RS-550 motors. What you have to careful with is the suffix: PH or HS. They are different.
pic: I think there's something wrong with these motors CD47-Bot Extra Discussion 4 31-03-2003 17:21
HELP!!! Drill motors needed! David66 Inventor 5 10-03-2003 16:38
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motors TF8 Motors 19 12-12-2001 13:13
