Re: pic: super scooter
Quick question if I may. How did you make the motors turn the same direction even though they are reveresly mounted from each other?? (if this answer is really simple I'm gonna fell stupid, so please make it sound complex.. lol) Can I just guess that you hooked one motor positive/positive-negative/negative and the other positive/negative-negative/positive? |
You guessed correctly |
Thanks for the info.. |
I am so tempted to build me one of these about how long the batteries good for and aproximate weight
So if I understand correctly, you essentially press the chia's shaft up against the wheel? Man, that IS crude.
![]() How hard do you think it would be to put some gearing on the back wheel? |
hey! how about some 4 speed gearboxes!! with a clutch, of course so you can really rev it and drop the clutch to burn some rubber..... or in this case, the tires arent rubber are they? well, then.. we need to get black rubber tires so the janitors can yell at us for putting too many rubber marks in the hallways! ![]() |
GreenCactus:Genius!
This is an excellent way to get some offseason practice in the fabrication of transmissions! w00t! It's got everything going for it:
So now my project is to make one of these with a four speed. A truly cool thing to do would be do make shifting automatic... ![]() |
| TCP/IP on a PIC | Venkatesh | Electrical | 1 | 11-18-2003 09:00 PM |
| pic: Another pic of Team 930 | CD47-Bot | Robot Showcase | 7 | 02-25-2003 09:07 PM |
| Dean on 60 Minutes 2 | archiver | 2001 | 7 | 06-24-2002 12:14 AM |
| Any Super Robots Yet? | SuperJake | General Forum | 9 | 01-25-2002 05:47 PM |
