Originally Posted by phrontist
So if I understand correctly, you essentially press the chia's shaft up against the wheel? Man, that IS crude.
How hard do you think it would be to put some gearing on the back wheel?
just a bit harder than a friction drive.. actually, i think cutting the rear end off completely and rebuidling a whole new rear end with a gearbox would be easier than attempting to squeeze somthing into what is already made compact........
hey! how about some 4 speed gearboxes!! with a clutch, of course so you can really rev it and drop the clutch to burn some rubber..... or in this case, the tires arent rubber are they? well, then.. we need to get black rubber tires so the janitors can yell at us for putting too many rubber marks in the hallways!
