Go to Post It is probable that you will find mroe than a few spotlight worthy phrases or sentences in the following. ;) - sanddrag [more]
Unread 30-08-2004, 21:57
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Re: White Paper Discuss: Team 179 conceptual - single speed - 3 motor gearbox
Originally Posted by Swampdude
Good so the stock carbon steel 24 pitch gears work :-)
I think I'm going to switch the bearings to the Sintered Bronze, Oilite flange bearings on Small parts - those things are $1.50 ea.
also going to look into the #609 loctite for gear bonding vs. welds
Now we're talking!
I strongly recomend staying with roller bearings. I have seen may teams learn this lesson.
The way I look at it, we are all limited by the amount of energy we can put into our motors. A design that has less parasitic losses will put more of that energy to the ground.
Matt"s
$0.02
White Paper Discuss: Continuing the Cycle: A Guide to Starting a University-Supported FIRST Team CD47-Bot Extra Discussion 2 15-05-2006 14:58
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
White Paper Discuss: Team 159 3.0 CD47-Bot Extra Discussion 2 24-06-2003 17:18
