Go to Post Remember that it's not what is on the outside of the shirt that matters, it's what is on the inside. - dtengineering [more]
Unread 04-09-2004, 23:39
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
Re: pic: Iso view
Originally Posted by RogerR
sweet drivetrain. about the weight estimates in CAD, is 60# the estimates for just the machined components, without the manufactured parts (i.e. motors, robot controller, battery) or did you already add those in? also, it looks like you might be using the cap screws in the front and back to move the wheel mounts back and forth, adjusting chain tension. is this the case? finally, how are the motors mounted? i can't tell from looking at the drawings, and its really messing with my head.
60# total weight
Cap screws do adj. chains
Motor mounts are slotted and bolted from underneath for a cleaner look
-Rod-
Team 662
Colorado Springs, CO
pic: 217 Robot ISO view CD47-Bot Robot Showcase 8 01-03-2004 13:09
pic: 710 2004 side view of drive train CD47-Bot Robot Showcase 6 16-02-2004 19:43
pic: Right Side view CD47-Bot Robot Showcase 2 03-03-2003 15:26
pic: 141's Robot stacking side view CD47-Bot Robot Showcase 7 28-02-2003 12:16
pic: 857 rear view programming CD47-Bot Robot Showcase 1 25-02-2003 22:24
